jag, ano ba yung mga dati/ or ibang kotseng gamit mo?
baka nasa throttle yan since electronic controlled na unlike dati cable type ang throttle ng mga kotse
Napansin ko na halos nawawala yung tunog once na up to normal temp na yung makina so I assume (and I don't claim to be an expert since hindi naman ako mechanical engineer, this is just based from my observation), it has something to do with fluid temperature and circulation.
I agree, mukhang dahil nga sa e-throttle and/or baka nasa mataas na gear lang since mabilis umakyat ng 4th or 5th yung tranny. I have learned to compensate by using sports mode and manually downshifting to 2nd/3rd kung kailangan talagang umovertake.
Mga sir another question, pag ba nagpakabit ako ng busina and alarm sa concorde eh mavo-void ang warranty? kasi mas mura sa kanila eh.
Gaano kataas yung pressure na nilalagay niyo sa gulong? Sabi kasi sa manual saka yung sa metal plate sa may driver-side B pillar, 33 psi pero ang max na nakalagay sa gulong ay 44 psi. Hindi ba sobrang under-inflated kung 33 psi lang talaga?
Ganoon din kasi yung sa xwind namin, 32 yung recommended pero 5 years na na 42 psi ko pina-inflate. So far OK pa naman yung gulong saka nag-improve yung FC.
dapat yung recommended ng manufacturer ang to be followed. pero per experience, if medyo mataas ng 2-3 psi sa recommended ay mag-iimprove yung gas mileage pero medyo stiff na yung ride. ok lang sakin na medyo stiff ang ride as long as makakatipid sa gas. hehe![]()
*lynx0
try to go to other dealers and check their GL models if it has an engine cover or none? will try to check din... parang ang weird naman that they removed the engine cover when in fact it should come as standard with all variants..
ako i only put 32psi on all tires... masyado matagtag ang 44 and kung longdriving may tendency na mag expand pa sya... will try to put nitrogen sa tires this weekend hehehe..
mukhang weird at kulang nga kung walang engine cover. Wag mo na lang buksan ang hood para di mo maalala na walang cover![]()
Hello Sir, kung wala pong engine cover, you can always opt to put a "Dynaliner". Here is the link to the site: http://www.dynamat.com/products_car_...liner.html#top
Marami naman pong dealers dito nyan. Usually sa mga nag seset-up ng mga Audio systems ng mga kotse. Meron din sa True Value.
Badtrip nung mga after a week namin makuha yung tucson pag check ko nung tire pressure nasa 50psi. Dapat inaayos nila yan pagka pre delivery.
*LadyRider
Yung tucson ngayon parang masyadong maraming rattles sa door panels pag nag papatugtog ng hindi naman sobrang lakas parang may nag rarattle sa panels. Mukhang dapat lagyan ng deadening material. Ganda pa naman ng stock speakers nya
sa E. Rodriguez dealer, wala akong nakitang engine cover ng manual
