Page 152 of 240 FirstFirst ... 52102142148149150151152153154155156162202 ... LastLast
Results 3,021 to 3,040 of 4793
    Apr 2011
    #3021
    Yung DPF naman, buti nlang wala HB natin nito. Di kasi pwede ang high sulfur diesel kasi pag nagbara at nag solidify yung sulfur sa DPF kailangan na palitan. Mahal rin itong part na into, parang P40k
    What about yung Dual Mass Flywheel for Manual Transmissions sir? Meron na kaya sa mga kasamahan natin nasiraan nun? I read some parts of the Carens forum and ang mahal daw ng part na to.
    Apr 2011
    #3022
    Double post
    Apr 2011
    #3023
    Quote Originally Posted by weisshorn View Post
    ^ i totally agree with you po. my 2007 1st gen tucson hindi pa rin mausok, once ko lang nabuksan at nalinisan ang egr at 45k odo. fairly clean pa naman sia at that time. using diesel from caltex, shell & petron when ever no unioil station around.
    Ilan na sir mileage ng Tucson ninyo ngayon?
    #3024
    Yep. Agreed.
    Wew, complicated nga pala ang CRDI. Hahaha. Maalaga ka talaga dapat.
    Dec 2014
    #3025
    Quote Originally Posted by epb888 View Post
    Sa Maspro banaue contact person Benjie..
    Very knowledgeable and quality of work..
    Thanks sir. Try ko dumaan pagpunta ko ng QC this coming weekend.
    Oo nga pala.. I just had my 1K PMS last Sat. Inabot ng 5.6K para sa FS, hindi na kasama yung engine flush at fuel treatment. May kasamang penetration oil, baka ginamit panglinis or lubrication kung saan man hehe..
    #3026
    Quote Originally Posted by simpl3_athan View Post
    Ako naman, gusto ko yung fuel injector cleaner pero Hindi KO pinapalagay sa kanila. Ako na lang naglalagay pag nagpa full tank ako.
    #3027
    Additives nga lang to noh? Ilalagay lang sa fuel tank?
    #3028
    Yes, I guess like any fuel injector cleaner. Para lang matanggal yung carbon deposits. Hinihingi ko at ako na lang naglalagay pag nagpa full tank ako. Ang ayoko ipalagay ay yung oil enhancer nila. Para pagka nag tagas yung langis, di naman tatagas into at bago pa. Mahal din, P850.
    Dec 2014
    #3029
    May ma-i-rerecommend ka ba sir na brand? or any brand will do?
    #3030
    Since nilalagyan nila every PMS at recommended every 5,000 kms, never pa ako sumubok ng ibang brand. Under warranty pa HB KO. May nakita ako sa handyman/true value, yung cyclomax fuel injector cleaner. Nakalagay recommended for common rail engines.
    #3031
    My 2010 accent( 1.5 crdi vgt u engine) na taxi at almost 250,000km mileage never pa nagkaproblema engine especially fuel injectors and the vgt. Regular change oil lang every 5000km with mineral oil (API - CI-4) , Changed air filter every 5,000km, replaced fuel filter and egr cleaning every 20,000km. Kaya i believe na no need na for our hb accent u2 engine sa mga additional fluids/cleaner na nilalagay ng casa. Yung taxi ko never nakatikim ng casa pms and repair. Sa suking talyer lang ginagawa ang pms and repair.😊
    #3032
    Quote Originally Posted by valskie01 View Post
    Interesting. Nung 2010 po ba available na run yung CI-4 oil satin? Saan kayo bumibili ng parts at saan talyer nyo po? For our data based para may options. Thanks po
    Dec 2014
    #3033
    My 2010 accent( 1.5 crdi vgt u engine) na taxi at almost 250,000km mileage never pa nagkaproblema engine especially fuel injectors and the vgt. Regular change oil lang every 5000km with mineral oil (API - CI-4) , Changed air filter every 5,000km, replaced fuel filter and egr cleaning every 20,000km. Kaya i believe na no need na for our hb accent u2 engine sa mga additional fluids/cleaner na nilalagay ng casa. Yung taxi ko never nakatikim ng casa pms and repair. Sa suking talyer lang ginagawa ang pms and repair.��
    Ang bangis sir ng accent 2010 nyo! Sana umabot din ng ganyang mileage yung HB ko without major problems.
    Aug 2012
    #3034
    CI-4 was introduced in 2002 so meron na nyan sa Pinas noong 2010.
    API CJ-4 (Current) - Introduced in 2006
    API CI-4 (Current) - Introduced in 2002
    API CH-4 (Current) - Introduced in 1998
    API CG-4 (Current) - Introduced in 1995
    API CF-4 (Current) - Introduced in 1990
    #3035
    Anong diesel ang gamit nyo bro?
    OT: Sa uncle ko kasi na truck, nasira yung fuel injectors. Ang dahilan daw kasi eh may tubig yung krudo. Malamang napapasukan ng tubig ang tanke ng gas station na pinagpapakargahan niya.
    Apr 2011
    #3036
    Anong brands mga sir ng langis ang API CI-4?
    Apr 2011
    #3037
    Your Accent's story is very inspiring. Sir anong brand ng oil ginagamit ninyo? Did you have to replace the clutch and dual mass flywheel in those 250,000 kms?
    #3038
    All my korean diesel cars usually sa goodgear, fronte and seiring ako bumibili ng parts. Egr cleaning, fuel filter, suspension parts and other repair sa goodgear or my suking mekaniko dito sa paco. Yes Since 2010 ci-4 rating mineral oil available na.
    #3039
    Petron trekker rev x gamit ko sa accent taxi.
    #3040
    Quote Originally Posted by airolynx View Post
    Dual mass flywheel hindi pa. Yung mga wear and tear parts ng transmission like clutch disc, pressure plate, release bearing, oil seal 2x na ako nagpalit. About every 80k-90k km ang palit ko. Feeling ko ang mahina sa mga korean cars yung auxilliary fan nila(halla brand oem) parang 2-3 times na ko nagpalit.
Hyundai ACCENT Hatch CRDI 1.6
