Page 79 of 160 FirstFirst ... 296975767778798081828389129 ... LastLast
Results 1,561 to 1,580 of 3189
    #1561
    Quote Originally Posted by Fredericko View Post
    what's the logic when doing this?
    may be they are pertaining in resetting the ecu, like hard reset. parang nag format ng computer gaganda ang performance. apllicable sya sa mga programming ng ecu na may bug pa
    #1562
    Yup, that's resetting the ECU. That's sort of an instantaneous way of having the computer re-check its parameters. This is also done when you make some upgrades/mods. Instead of having the ECU 'learn' the new mods over time, you are putting it to sleep and slapping it awake right away.
    #1563
    is it the same with fiesta?
    Jul 2010
    #1564
    Quote Originally Posted by spymaker View Post
    sa ford fiesta thread. they disconnected the negative terminal ng battery for 5 minutes, press the brake during that time, then reconnect terminal. nag improve fc and gear change ng at nila. baka pwede yan sa inyo.
    Has anyone tried this already? Any update?
    I travelled from Sto. Tomas to Vigan. Had full tank (sagad up to apaw) and when I arrived in Vigan, still had 3 bars left. Hataw mode pala to.
    In the monitor I had 7.6L/100Km ~ 13.15Km/L.
    While city driving here in Vigan, my FC is at 11.3L/100Km ~ 8.85Km/L
    Is this consumption normal?
    My Odo now is 860+, so nearing my 1st PMS. I plan to have it done in Hyundai Laoag, any elantra owners who have experience in Laoag?
    Cause I plan to use semi-synthetic oil.
    Appreciate your feedback. Thanks.
    #1565
    Yes it's true. You can do that sa mga de-ECU. Sa Honda naman wala na kailangan gawin na iba just disconnect the negative pole.
    Sa Hyundai ganun din, disconnect the negative pole, 30 minutes is enough para sure na naka-reset ang ECU. Or pagawa niyo via GDS, better yun.
    #1566
    Feb 2005
    #1567
    was anyone able to make the inner tail lights work when the headlamps are on?
    #1568
    Quote Originally Posted by t43m4n View Post
    i just install it last nyt and its look good when lighted, may abang na sa terminal ng reverse light., bumili lang ako ng peanut bulb socket sa banawe then, drill the hole , may pattern naman sa tail garnish
    Feb 2005
    #1569
    Ow di ako magaling mag DIY. Just drill the hole and plug in the peanut bulb? how about the wires?
    Aug 2004
    #1570
    Quote Originally Posted by Jackdripah View Post
    Sounds reasonable, i heard many people are changing to fully synthetic after its properly broken-in. around 10T km...
    sounds reasonable, accdg to US Govt. EPA measurements, the car can do 40mpg (hiway) so that's around 17km/li... pero since ang hiway naman sa atin ay madami dami din ang slowdown and re-acceleration. kaya siguro mas mababa. pero not bad na 'yan...
    tungkol naman sa oil, normally mga 10T km. sila nag papalit to semi-or fully synthetic oil.
    #1571
    yun wires may terminal na green and black sa socket ng reverse light ,you dont need to run it all the way to tail light, just dnt know if the same with 1.6
    #1572
    hello my fellow Elantra owners
    we are cooking something to enhance our driving experience and to give more value in the interior of our Elantra, check this out.
    the head unit in the left is from my wife's Elantra which we dismantled to be the guinea pig.
    the panel at the right is the prototype, some flaws are still there.
    prototype panel, we still have to refine some glitches.
    May 2011
    #1573
    Quote Originally Posted by lurkercar View Post
    Maglagay kayo ng LCD sir?
    I admire your skill.
    Jul 2011
    #1574
    waiting for an upgrade soon like the GPS-NAVIGATOR 2DIN, need the same panel as above. Wondering how much for this upgrade ?
    #1575
    Quote Originally Posted by ReyMatt View Post
    we are working on the prototype OEM DVD with GPS for our ELantra. We have the mainboard po kasi that works well on Garmin GPS kahit na high resolution LCD panel ang screen, BT, Ipod, rear camera, DVD are some basic feature.
    will post soon once tapos na ang buong HU.
    #1576
    Jul 2011
    #1577
    *lurkercar: How much budget po for the OEM HU ?
    Thanks.
    #1578
    Quote Originally Posted by bmallillin View Post
    Thanks.
    sir, cannot estimate yet magkano, pero you can check our sulit ads sa mga OEM HU namin na successful na ang pagkagawa. We do reverse engineering sa mga HU using the stock panel for opening a mould. The best thing is that we perfected the compatibility of Garmin on our HU unlike ung ibang OEM HU na naghahang or hindi stable ang Garmin GPS. you can view some models here: Lurker Car (carlurker) Philippines
    one thing yet to be done is the OEM fit rear camera, I think mahuhuli to than the HU.
    Jul 2011
    #1579
    wow, saw your sulit page, have to make "ipon" na for it! Pls do post here in tsikot.com once you're ready. Thanks.
    Jul 2011
    #1580
    I'm almost ready to pull the trigger on a 1.6 m/t elantra.. But before I do, please do post here any negatves that you have on your units.
    some questions I have on elantra users:
    Is the suspension ok? meaning that is it not too soft much like what I'm reading about the accent (that easily bottoms out)?
    For M/T users, how's the clutch action and gears? (too bad hyundai does not have a test drive of the 1.6 M/T units but I'm still pushing my SA for one). Also how is the reverse gear implemented? Has it got a ring to pullu p in order to select reverse gear and prevent it to be selected when you are aiming for the first gear (much like what is found on the previous gen accent)?
    Any niggles on the overall build quality this early?
    Thanks!
2011 Hyundai Elantra [MERGED]
