Results 7,541 to 7,550 of 8077
- Apr 2012
- 3,469
July 14th, 2018 07:39 PM #7541
July 14th, 2018 08:50 PM #7542
- Apr 2012
- 3,469
July 14th, 2018 08:53 PM #7543Hataw if given a chance na maluwag talaga. Pero nung bagong kuha ko to pagka skyway ko hinataw ko ng 160 agad 🤣
Good old days hehehe
Planning to have the intake cleaned, may oil residues na kasi. Baka palitin na din intake manifold gasket. Pati suspension bushing ppa check ko na din.
BTT: may nakapag palit na ba ng atf dito via dialysis? Ilang litres aabutin?
Planning sana ipababa yung transmission pan para malinis filter.
Had drain and refill nung 40k kms. Sent from my SM-J730G using Tapatalk
July 14th, 2018 09:52 PM #7544
When my unit had low power, had my ERG blanked and CAT removed para hindi na maulit ang low power. Not sure how they removed the inside of the CAT converter since iniwan ko lang sa tayer ng kaibigan ko.
Had ATF dialysis before sa banawe and kinaya ng 12liters of castrol multivehicle atf
- Apr 2012
- 3,469
July 14th, 2018 10:25 PM #7545
July 14th, 2018 11:38 PM #7546
July 14th, 2018 11:49 PM #7547
July 16th, 2018 11:47 PM #7548
Depends on how clean you want it. It took 15 liters with mine before. No need to open the tranny pan. Filter is not a filter, it's a screen wire mesh and since it's a sealed tranny i would not worry about it unless you have metal in the oil (which of course means you have much bigger problems that the filter/strainer.)
July 17th, 2018 12:38 AM #7549
July 18th, 2018 05:07 PM #7550
lotus elise all the way! 2004 edition
Lotus returns...
