Results 6,541 to 6,550 of 8071
April 4th, 2016 12:51 PM #6541
I feel for you bro..
Unfortunately (and frankly), I do not have the answer to your questions, as I have not experienced them. The couple of limp modes I experienced earlier disappeared after resting the engine and restarting, and never happened again (never drove the engine hard again on a continuous incline.. )....
Let's keep this humming and on the top page so that the experts or those with similar (hopefully the same) experience who were able to recover,- can chime in....
29.2K _/_/_/_/_/_/_/_/_/_/
- Sep 2015
- 90
April 4th, 2016 12:51 PM #6542sir lagi ko binabantayan ang panel,pro wala siya nailaw kahit check engine,, una ko kasing napuna sa coffeshop sa tagaytay malapit sa picnicgroove, parang 45 ang angle non paakyat, yun nga gapang siya kahit lima lang kaming sakay,, sumunod sa batangas sa lobo sa gilid ng bundok ang daan paakyat pa baba parang talisay twice nako pumunta don same siya gapang lang talaga,,, ano nga pala yung limp mode??hehe
- Sep 2015
- 90
BANNED BANNED BANNED
- Mar 2009
- 81
- Sep 2015
- 90
- Mar 2009
- 81
- Aug 2007
- 51
April 7th, 2016 12:33 PM #6547sir pag nangyayare ba yan napapansin mo kung mausok yung buga ng exhaust? naeexperience ko din kasi to minsan. kahit todo apak sa accelerator halos hindi umaarangkada. ginagawa ko nalang nilalagay ko sa neutral tapos binobomba ko. daming usok na lalabas tapos after that okay na. ang hirap lang intermittent yung problem. minsan wala minsan mangyayare bigla. blocked naman na EGR ko at pinalinis ko din bago iblock. regular din ako magpalit ng fuel filter every 10k kms. Hindi ko din alam kung anong culprit.
- Mar 2009
- 81
April 7th, 2016 01:15 PM #6548Hello, I have customers who experienced the same issue, there is carbon deposit inside of your engine, most likely on your fuel injector and intake valves, that could be the cause of lack of fuel supply, hence your car will not accelerate well even you floor it.
Have your whole engine system de-carbonized, that includes fuel injector, EGR, Turbocharger, DPF, Oxygen sensors, Catalytic converter, Intake valves and Manifold, it will make your car run like new.
For more information, please visit: El Cilindro
- Mar 2009
- 81
April 7th, 2016 01:23 PM #6549Engines are designed to create the proper environment for combustion, but are not designed to extract all of the energy from fuel. During the combustion process, there are portions of fuel that are just not completely combusted. They end up either in the exhaust, or attached to the surfaces of the combustion chamber. Carbon deposits are mostly carbon and aromatic compounds in a highly combustion resistant state.
In layman’s terms, a carbon deposit is left over hydrocarbon chains (fuel) because your engine couldn’t burn it all.
There are a number of issues caused by carbon build up. When larger deposits are formed, they reduce the smooth air flow intended by the engine manufacturer that can hinder optimal mixture with air for combustion, as well as reduced air delivery. Unconsumed fuel can also escape the combustion chamber in the exhaust, but can get trapped along the way on sensors and catalytic converters. Misreadings from sensors can cause increased fuel delivery to the engine, reducing fuel economy.
Look and listen for the following:
-Rough idle
-Smoke
-Reduced Fuel Economy
-Less power on request
This is why engines need to be de-carbonized, recommended every 10,000 kms or once a year, to have them properly maintained and prolong their lives, not to mention to better protect our environment.
- Sep 2015
- 90
April 7th, 2016 01:30 PM #6550
high idle RPM at engine start
