Results 1 to 5 of 5
- Feb 2009
- 11
March 8th, 2009 02:03 AM #1mga bossing,, pansin ko lang kasi medyo tagilid ang gulong ko sa likod, ung upper part leaning inside,(papasok sa loob).. saan kaya problema nun?.. kasi napupudpud ung tyre ko sa lood,, di pantay,, tnx
- Jan 2008
- 4,726
March 8th, 2009 02:06 AM #2mahirap sagutin ang tanong pag kulang sa detalye at least may type or model ng car...
most probably its a camber problem...
solution?? hindi pa alam kasi hindi din alam kung ano kotse nyo
March 8th, 2009 02:52 AM #3
Yapoy is right, some car have adjustable camber so its alot easier if you can explain in more detail about your car.
Anyway, obviously this is the camber angle causing this. It's 100 % not the strut. I would find a reputable shop where you live that does free estimates on these sorts of things and take advantage of that. Most likely, it's a bent control arm.
- Feb 2009
- 11
March 8th, 2009 11:37 PM #5
Just shooting ideas in the air:
If the car was lowered without installing a camber kit, that will put the camber into the wrong geometry. Either that or the rear springs are getting saggy.
Apparently, that's turning out to be a rather small crowd.
