Results 1 to 5 of 5
    Feb 2009
    mga bossing,, pansin ko lang kasi medyo tagilid ang gulong ko sa likod, ung upper part leaning inside,(papasok sa loob).. saan kaya problema nun?.. kasi napupudpud ung tyre ko sa lood,, di pantay,, tnx
    Jan 2008
    mahirap sagutin ang tanong pag kulang sa detalye at least may type or model ng car...
    most probably its a camber problem...
    solution?? hindi pa alam kasi hindi din alam kung ano kotse nyo
    May 2007
    Yapoy is right, some car have adjustable camber so its alot easier if you can explain in more detail about your car.
    Anyway, obviously this is the camber angle causing this. It's 100 % not the strut. I would find a reputable shop where you live that does free estimates on these sorts of things and take advantage of that. Most likely, it's a bent control arm.
    Feb 2009
    honda civic vti 98 po ang car.. posible po ba sa shock un?. salamat po
    Jan 2009
    Just shooting ideas in the air:
    If the car was lowered without installing a camber kit, that will put the camber into the wrong geometry. Either that or the rear springs are getting saggy.
tagilid ang gulong sa likod
