Results 1 to 8 of 8
July 18th, 2006 04:46 PM #1
Good day to all!
Guys, I just wanna ask your suggestions. I bought a lowered 97 civic, and i find the front end too low. Now, I wanna lift a little, say 1.5 inches. How shall i do it without changing the springs. Thanks in advance.
July 18th, 2006 04:54 PM #2
depends on what was done to lower the car.
example:
-front springs were cut while the rear springs are stock & untouched. simply replace the fereront springs with stock springs will solve the problem.
July 18th, 2006 05:08 PM #3
Cut or lowerings ba ang ginamit?Kung cut lagyan mo ng lifter.Sa una hindi matagtag pero pagtumagal matagtag na or replace the springs to avoid the tagtag ride..
July 18th, 2006 05:21 PM #4
if you want to bring it back to stock.. look for stock springs surplus... it will resolve the issue
July 18th, 2006 05:25 PM #5
thanks for the response guys. i appreciate it.... i'll try to deteremine whether the springs were cut or replaced. if the springs were replaced, approximately, how much does a stock spring cost?
July 18th, 2006 06:31 PM #7
actually less than 1K. sa banawe 600 petot each ang springs. palit stock na lang yan solve na problem mo.
July 18th, 2006 06:45 PM #8
Swerte mo if the springs that are installed now are not cut, and is a real lowering springs... tago mo nalang pag gusto mo na ibalik tsk tsk
Before the power run both filters are already primed so pre-fill should no longer be an issue, but...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
