Results 1 to 10 of 48
- Sep 2009
- 15
April 12th, 2010 08:58 AM #1mga sir, quick question lang. Im using 96 honda civic lxi. Napansin ko kasi ang lakas sa gas. FC ko is 6 only.pag medyo sinuwerte, 7. Pag long drive 10. Light footed naman ako. In fact ang rpm ko does not go beyond 2k as much as possible. Recently,pinalitan ko mga spark plugs ko,palit din ng air filter. About a month ago, change oil naman. Also,palyado ung makina about a month ago din so pinalitan ko hi-ten wire ko. Sa ngyn, maganda na kundisyon ng oto. Yun lang ang lakas naman sa gas. Sa tingin nyo mga sir,pano kya gagawin ko para tumipid sa gas ung oto? Dami nagsasabi dapat daw at least 10 ang FC ko pg city driving e. Tnx in advance mga sir.
- Nov 2009
- 456
April 12th, 2010 10:31 AM #2Well for starters wala ba kayo bagahe na pwede alisin sa kotse? Baka nagpapabigat lang kaya mas hirap ang makina. Check nyo din ang tires nyo kung nasa tamang pressure. Kung underinflated ang gulong malaking factor din yan sa pagconsume ng fuel.
Ano pala kinakarga nyo na gas? Kung E10 na, medyo mas malakas ng konti mag consume ang makina kesa sa pure gasoline.
April 12th, 2010 10:35 AM #3
April 12th, 2010 10:40 AM #4
You could try checking the following:
-wheel alignment (toe, chamber, etc)
-wheel bearings (are they in need of repacking or replacing?)
-brakes (are the pads rubbing the brake rotors?)
-engine accesories (are the A/C compressor and alternator easy to turn or getting too stiff? Their bearings might start to wear out, adding to the load of the engine.)
-engine cylinder compression test (there might be a cylinder leak which might cause the engine to produce less power and consume more fuel as well)
-exhaust system (a hole in the exhaust system can cause less power and increased FC)
BANNER BANNER BANNER
- Jun 2008
- 1,439
April 12th, 2010 11:05 AM #5Also check the sensors. A couple of busted sensors on my friend's SiR made car use up more gas. After replacing it, he claimed that the car's fuel mileage improved by at least 1km/L.
- Nov 2009
- 18
April 12th, 2010 03:09 PM #6sir clear ko lang po pag sira ba yun bearing ng alternator,possible po ba na lumakas sa gas?yun oto ko kc mukang sira na yun bearing ng alternator kc maingay na..pos medyo malakas nga sya sa gas ngayon..konting explanation naman po sir regarding that..sensyana po sir..salamat in advance.
April 12th, 2010 07:05 PM #7
i doubt na may kinalaman ang bearing ng alternator sa lakas ng fc mo...kung meron man minimal lang ingay lang pag sira na bearing...baka sir car full ka plus bagahe talagang malakas sa gas pag ganun..try mo sir na ikaw lang mag isa tanggal lahat ng anything na nagpapabigat sa kotse sigurado mag iimprove fc mo
baka mali ang pagkatune up usually meron ginagamit na timing light ang mekaniko kasi meron silang tinatapat na gatla gatla na 10,5,0 sa crankshaft fulley..kung wala timing light patsamba lang yun..
April 12th, 2010 07:11 PM #8
- Nov 2009
- 18
April 13th, 2010 12:42 AM #10
