Mga sir, tumatakbo po ako around 80kmh sa sky way, mga 30secs siguro, tapos diniin ko apak sa accelerator para mag 100kmh sana, pero wala akong power, 80kmh pa din. Pag bitaw ko, at bumaba konti speed tapos apak uli.. Saka nag accelerate. Ano po kaya issue ng crv ko? 3rd gen po, 2007 4.2. Salamats!
Two factors i could think of, i used to have a 2007 crv, maybe you where at an incline and going thats why it was harder to accelerate and when you stepped on the gas again you were over the portion that was going up, 2nd explaination is the wind (addition drag) going the opposite direction. Like what i said, i used to have one, its a guzzler and lacks power, btw when was the last time you changed the ATF? That is also a cause of unresponsiveness.
Does your CRV have ABS?
I just learned yesterday my CRV 2004 has no ABS (Anti-braking locking system). I thought all along it had. Some years ago. My car skid as I pressed the brake on a traffic stop. Good the cars perpendicular hadn't started yet. Do you think it's safe driving a car without ABS? I'm thinking whether to sell my CRV 2004 or retained using it (as extra on coding day).
no abs? imposible, the 2nd gen 2001 already has the ABS...
the ABS only automates the braking system for it not to lockup and skid for you to have vehicle control while braking, without it you have to learn how to do the manual mode aka proper braking techniques which you should basically know just in case your ABS fails!
as my saying goes, you cant go to the advance, without learning the basics (just like learn MT first before going AT)
I brought the car to Honda Shaw, the service advisors looked at the front hood components and said they was no ABS (see picture, it should be present near the steering fluid container). Also when you started the car, there was no ABS on the upper left side. I think only CRV EX has it.. the CRV LX doesn't have it. When you have a car in front of you suddenly stopping in the middle of highway. Only ABS equipped car can make you adjust the steering. If you will manually step on the brake and release and step dozens of times a dozen a second or two.. it's not possible in that 2 second critical period when all you can focus is stepping on the brake.
Who else has no ABS in their CRV?
Big18. Do you know the minimum speed before the CRV would skid when brakes suddenly applied (like when the car in front suddenly stops or a person suddenly appears)? So I can keep it to the minimum speed for this backup car. For 12 years. I thought it had ABS so I could make it run at even 100 kilometers per hour.. but knowing now it doesn't have ABS.. need to just maintain that minimum speed when the car is still steerable when brakes applied suddenly. In emergency situation like the car in front stopping.. you want to apply brakes as hard as possible to make sure it stops. In split seconds you cant decide to do threshold braking (or releasing and stepping dozens of times a second or so).
For the abovementioned situations, a collision sensor would help you more than an abs. Only time an abs might be needed is when you are recklessly speeding on a wet slippery highway.
I always hate hearing an accident on tv where a driver reasons "biglang preno yung nasa harap ko e". It only means that the guy was driving too close without a safety margin. ABS won't avert it. But your not this guy because you care for safety.
ako as a personal rule, i always maintain a one-car-length distance (at least) guide when i'm driving around in moderate speeds. and then i add more distance to the car in front of me as i drive faster ( wherever higher car speeds can be attained)
pero wala talaga abs iyong '12 crv model? naka k20 na kasi engine niyan kaya i expect abs equipped na siya kaya medyo nagulat ako sa sabi ni bro k_leos
yes, that ABS metal box with its cute metal tubings is hard to miss.
how's your third row, sir? is it front-facing, or jeepney style? if the latter, this may have been the special edition designed to take advantage of the tax-friendly laws for mass-carrier vehicles at that time. removing the ABS was probably another attempt at reducing the CRV's admittedly higher price, then...
when a rear fender and a front fender bump, the default assumption is that the car behind was following too close and/or too fast. "the only way i can think of to change this assumption, is to prove that the car in front backed up."
there's this three-second rule. at any decent speed, have at least three seconds of response time between your car and the one in front.
ABS can only help the driver control his vehicle. ABS does not make the vehicle idiot-proof.
Hi,
Confirm ko lang. Mas matipid sa gas ang 2.0 vs 2.4 city driving right?
I'm looking forward to buy a 2008 CRV, either 2.0 or 2.4.
Mostly city driving lang.
