Results 651 to 660 of 1220
- Aug 2006
- 3
April 28th, 2015 04:17 PM #651Mga Bossing/Gurus,
planning to buy a CRV Gen 3 (2007-2009) budget permits, ask ko lang po kung ano ang difference beetween 2007 from 2008 to 2009? in terms of FC and ride and accessories? 4x4 po sana yung balak ko. pang pamilya ( oldies ) kasi medyo lumalaki na po ang pamilya eh at need the leg room narin. nag check po ako dito at sa ******* eh nasa 500-700K (2007-2009) ang range ng CRV gen3. tama po ba yun or medyo me kamahalan? Knowing Honda. mataas parin ang resale value. maintenance wise and FC , is it advisable to buy an 8 yr old car? thanks in advance mga bossin.Last edited by slow_jun; April 28th, 2015 at 04:31 PM. Reason: double post
- May 2015
- 2
May 23rd, 2015 01:20 PM #652Hi Guys,
May alam ka bang nag se-service ng ignition key ng honda crv 2003~2004 model, i just tried a duplicate key then yung original key hirap na rin pumasok pero gumagana naman, parang may tinamaan sa loob ng key entry, naita ako sa youtube, linis at spring replacement lang yung pinakitang solution, problem ko lang i wanted a reliable key servicing guys... can you recommend one ASAP lang aksi... and sorry if short notice.
Thanks!
Hi Guys,
Thanks!
May 23rd, 2015 03:09 PM #653
May 24th, 2015 10:34 PM #654
- May 2011
- 227
May 24th, 2015 10:43 PM #655Wow ang mahal 6k bili na lang din ako ng nut lock t will just cost me 800 sa mall ah hehe
Anyway does anyone know kung bakit umingay un makina ng crv pag idle? Pag nag rev ka onti mawawala tapos babalik ulit pag idle? I already checked all fluids ayos naman un pan belt ba un pansin ko naging malangis siya dati un hinawakan ko un di naman malangis di nadumihan kamay ko noon ngayon ang dumi na haha. Next schedule oild change next month pa. Last December change oil at change coolant lang naman ginawa at some checking un mga dapat palitan. Dati kasi tahimik un andar even idle un crv pero ngayon may ingay na. I will try to post a video later regarding sa noise ng crv ko
- May 2011
- 227
May 25th, 2015 05:10 AM #656Hi its me again I think un tunog is from aircon pag bukas siya tapos idle maingay tapos pag nag rev or natakbo na nawawala. Pero pag naka off un aircon wala naman tunog. Will upload video later so you hear the sound
- May 2011
- 227
May 25th, 2015 06:33 AM #657https://youtu.be/PakfMANZF-I here is the video sorry kung madilim pero rinig un difference nun sounds un malakas na noise is naka on un aircoun un medyo humina un ang naka off
May 25th, 2015 10:57 AM #658
Check the AC compressor bearing, nangyari sa 1st Gen V ko yan, after long drive - Cavite - Subic - Alaminos Pangasinan - Vigan - Baguio.. When i reach Baguio dun na bumigay yung AC Compressor Bearing. Ok naman yung Temp ng AC, maingay lang talaga. Kaya ng umuwi ako from Baguio to Cavite parang Helicopter yung tunog ng V pag naka open ang hood. Replace agad ng AC compressor, presto wala ng tunog.. 14K ang damage.
May 25th, 2015 12:30 PM #659
Pa-check mo muna sa reliable aircon shop. Tapos kung compressor nga may sira, sa labas ka bumili mas mura kaysa sa aircon shop.
- May 2011
- 227
May 25th, 2015 03:32 PM #660As expected nga when I google the problem yan din lumabas haha pero ganun ba talaga even na may lamig or walang problem un AC when in comes to the temp no problem at all. Pero un tunog ala helicopter nga ang ingay pag naka on un AC at idle. Pag nag pa change oil ba ko sa dealer same lang din kaya un makikita nila problem?
