If your EK is the facelifted model (same body type as the SiR with multi-reflector tail lights, may abang para sa fog lamps sa front bumper), then it should be compatible.
However, if it's still the 1st gen EK body, then it isn't compliant with E10.
Mga Hondas,what is the best gasoline sa honda civic vti 1997?Shell unleaded?Caltex Silver?petron unleaded?Yan lang mga kinakarga ko sa honda ko.Before when I still in province,Petron o shell lang.Pero nun nalaman ko na ang caltex silver daw ay maganda sa makina at matipid daw,caltex silver nako palagi.
Petron Blaze nalang yata walang E10 pero ang mahal.pero lalakas daw hatak sasakyan pag eto gamit.totoo?
Does anybody have an idea if it's possible to convert a Fuel-Injected car which is not yet compatible to E10 fuel? I have a Honda City 1999 LXi (Not the Type Z model), and honda posted it that it's not yet compatible for E10. I have already loaded it up with XCS for a couple of months until I discovered honda's posting.
I'll be loading up with Blaze until there's a solution for conversion.
I'd like to know if you guys have an idea on how much it will cost if there's a conversion kit available.
Thanks!![]()
I believe Petron's BLAZE also has blended enthanol.
Good thing that you have EFI . . . think of the other old cars that still has carburated engines. :twak: it is even much worse!
i have a 99 carb corolla that runs e10 blended petrol with no drama, apart from a corroded canister valve and somewhat bad fuel economy (1.3 engine gets only 7-8, wtf? minsan it's 6-7 pag barado na air filter).
my previous 96 and 99 civic a/t ran e10 just fine and dandy.
my 98 a32 even likes seaoil extreme e10.
so my opinion here is: if it ain't broke, don't fix it. run that baby on any petrol you like until the engine breaks. then replace the whole engine na lang (which, i think, is more cost effective than repairing the old one and converting it to run like a flex fuel vehicle) then run another 100,000 kms.
by then, wasak na yung kotse. time for a new one which ought to be compatible with e10 by then.
problems on EFI cars with E10 would include (but not limited to) the following:
-rust in the gas tank (from the water content in the e10 gasoline)
-hardening of the non-ethanol compatible rubber fuel hoses.
-erosion/corrosion of some metal fuel hoses (resulting in pin hole leaks).
thanks for the info. so is there a way to replace the affected parts to make it compatible for E10?*ghosthunter
and also, what is the safest fuel to load for now? my first option, as what i've already stated on my first post, is Petron Blaze.
pag ethanol-blended lang yung fuel (not 10%-90% mixture), like XCS (if i'm not mistaken, is not E10 but still contains ethanol -- around 5%?), me negative effect pa din kaya sa kotse?
naninigurado lang.. i'm currenly draining the currently loaded XCS. just making sure na tama yung maikakarga ko after
thanks again.
Kaya pala from 9.5km/L bumagsak ako ng 6.5km/L possible ba yun mga sir using 96 civic vti
Sent from my LG-F400L using Tsikot Forums mobile app
