GD users, does anyone know if the L13A (idsi) and L15A (vtec) share the same stock exhaust setup?
same diameter? same resonator length? etc..
nasira yung shifter ko... di na makagalaw from P to any other gear parang naka lock. tried using the shift lock but to no avail. sabi yung brake sensor daw, sana ok lang to..
just to update you on my concern, nasira pala yung button nang shift knob to engage my gears. tinanggal yung shift knob at ngayon bare na yung shifter ko. wonder where i could buy the shift knob?
try mo sir ask kay jay ng isahaya (https://www.facebook.com/IsahayaAutoParts).. he has many gd surplus parts.
Wala sir. Sobrang flywheel lang yan. Baka may interesado. Nung bumili kasi ako ng tranny, may kasama na flywheel but since buo pa yung stock, yun pa din yung pinakabit ko.
Sent from my iPad using Tsikot Forums
Sa mga GD dyan na may nginig kapag malamig ang makina try nyo magpalit ng TPS. yun sakin pinalitan ko ng TPS nawala yung nginig at tumipid sa gas. Sinabay ko na rin palit ng tranny fluid.
Yung sakin nakuha ko ng 2.5k kasama labor sa banawe.
TPS = Throttle Positioning Sensor
Nililinis lang ang idle control niyan.. may dalawang bearing and binibugahan ng carb cleaner and some grease oil..
I never had issues with my jazz dati sa idle during hot or cold
nag check engine kasi sir, at TPS ang lumabas sa scanner. kaya kailangan talga magpalit ako ng TPS
how much is the tps sir?
additional inquiry... saan kayo mga sir nag papa duplicate ng susi ng GD?
Im also interested sa paduplicate ng key, how much sa inyo?
And another thing, has anybody also experience na lumuluwang yung front shock mount?
Bago shock mount ko, had them replaced mid last year, OEM,lumuwang sya after 4 months,
So i think normal lang yun kasi medyo nagsettle na yung rubber, ngayon lately,
Andyan nanaman yung distinct thug sound ng maluwang na shock mount, minsan lang naman
Pag medyo malalim yung pothole.
Right side sya, and i checked kanina, mas malaki nga ng konti yung clearance ng right side,
Manghiram lang ako sa officemate ko ng 17 na open type wrench, ndi pde yung socket set,
Ndi kasya.
Hi guys/ gals, i have Power Window switch for LHD cars.....very useful for those Subic/Cagayan acquired to make proper conversion.
Posted via Tsikot Mobile App
saan nakakabili ng tonneau cover. meron sa sulit 4.5k baka sakali may makuhanan ng mas mura.
