Page 1 of 5 12345 LastLast
Results 1 to 20 of 255
    Jul 2011
    No thread available yet for the first gen Jazz GD body. might as well create one.
    Anyway, mga sir/maam, may concern lang ako sa Jazz GD ko,
    its been raining pretty hard lately and nakita ko na may nag-se-seep in na tubig at naiipon sa spare tire compartment sa likod. so i immediately it off and silip silip sa kung saan nanggaling, opened rear hatch, tinanggal ko yung plastic cover ng lock sa baba and i noticed na nanggagaling yung seep of water dun sa pagitan nung dalawang yero na na nagmeet and covered by the weather strip rubber sa labas. (I hope i described it right) if light rain lang wala naman.
    anyone had theses problem? i tried silicone pero no luck, meron parin onte nagseseep at naiipon sa spare tire compartment,
    ive asked the price of a new weather strip sa casa,and reasonable naman sakin ang price, last resort ko na yun if ever hindi talaga masolusyonan, pero kung meh alam kayo iba paraan, pwede ko subukan.
    thanks!
    this is a common problem sa 1st gen jazz btw, ive looked into fitfreak and some forumers there experience din this water seepage sa tire compartment, anyone here had the same problem? ano ginawa nyo solution? would it be better ba na tanggalin ko yung buong weather strip and pasiksikan ko ng masilya yung meeting point ng yero? yung silicone kasi parang hindi effective, may lumulusot padin.
    Jul 2011
    Problem solved.
    Spent my afternoon doing leak test of my own and surfing then net for possible causes, and fortunately, may nakita ako sa website na dedicated lang sa leaking trunk ng first gen jazz, and sapul, parehas kami ng problem, okei na. Salamat sa mga nag-atubiling mag-basa.
    Dec 2007
    good to know your problem is solve sir...
    yung gd manual namin na nag-i-stuckup yung clutch pedal kailangan pa itaas para bumalik. clutch master kaya problem? if yes how much kaya abutin if pagawa and saan ok aside from casa?
    Dec 2002
    ^ ganyan nangyari sa akin kaso ibang oto. nakitang problema may leak sa clutch cylinder slave at kailangan ng ireplace. yung master walang problema kasi bagong palit 3 yrs. pa lang nagagamit.
    pacheck mo muna sa trusted shop.
    Dec 2007
    thanks rc-v, dinala ko kanina sa wheelers banawe... rebleed nila at adjust dun sa may clutch pedal ok na.. obserbahan at pag umulit malamang talagang master na sira...
    Last edited by b16sir_stock; July 1st, 2013 at 01:41 PM. Reason: typo error on "banawe"
    Dec 2007
    have anyone tried to correct the rear camber of your GD using the shim/washer process as shown on fitfreak?
    Sep 2013
    Quote Originally Posted by 7138 View Post
    Problem solved.
    sakin din meron konti napansin ko papano ginawa mo solution sir
    Sent from my F3215 using Tapatalk
    Aug 2013
    Kung Jazz GD automatic model sir, yes, CVT transmission niya.
    Sent from my mind using Telepathy 2
    Sep 2009
    FS
    Sent from my iPad using Tsikot Forums
    Sep 2009
    FS
    Mar 2012
    Anong nangyari dito sir?
    Posted via Tsikot Mobile App
    Sep 2009
    Wala sir. Sobrang flywheel lang yan. Baka may interesado. Nung bumili kasi ako ng tranny, may kasama na flywheel but since buo pa yung stock, yun pa din yung pinakabit ko.
    Dec 2013
    Sa mga GD dyan na may nginig kapag malamig ang makina try nyo magpalit ng TPS. yun sakin pinalitan ko ng TPS nawala yung nginig at tumipid sa gas. Sinabay ko na rin palit ng tranny fluid.
    Quote Originally Posted by luckymouse19 View Post
    Magkano papalit nyan?
    Mar 2012
    ano nga ba TPS? sorry. hehehe.
    Dec 2013
    Yung sakin nakuha ko ng 2.5k kasama labor sa banawe.
    TPS = Throttle Positioning Sensor
    Jul 2010
    Nililinis lang ang idle control niyan.. may dalawang bearing and binibugahan ng carb cleaner and some grease oil..
    I never had issues with my jazz dati sa idle during hot or cold
    Dec 2013
    nag check engine kasi sir, at TPS ang lumabas sa scanner. kaya kailangan talga magpalit ako ng TPS
    Dec 2007
    how much is the tps sir?
    additional inquiry... saan kayo mga sir nag papa duplicate ng susi ng GD?
    Dec 2013
    Quote Originally Posted by b16sir_stock View Post
    2.5k yung sakin, kasama labor. sa banawe ako nakabili
First Gen Honda Jazz/Fit (GD) discussion
