I have a 10 yr old Jazz. 1st owner. I will try to answer your questions.
Cge nga.
Pagnakatigil at negmenor ang makina bakit humihina ang Fan ng aircon ko?
mgs boss san ba nakakabili ng shock mount pang jazz gd3? nakaangat yung shocks ko eh.. kita mo nakaangat kapag binuksan yung hood.
bakabili nko shockmount sa alabang parts.. 480 isa.. patira ko kay mel bukas![]()
Mga sir bat kaya ganon yng jazz ko pag nag drive ako tpos reverse tpos balik ulit sa drive parang nanginginig.. AT jazz ko. sa engine support kaya yun?
Meron ako City 2008 MT, bigla lang nag ilaw yung EPS sa dash tapos mabigat iliko. Nag chk ako ng fuse buo naman. Ano kaya sira at kailangang ipagawa? Salamat po.
mga sir palitin po ba tlga ang thermostat ng honda jazz 2005 1.5vtec matic? hindi po kasi nag on rad fan kapag patay aircon eh..
Hi there, I‘m currently considering buying a used Jazz
Have enough cash for a either a GD or a GE
I do wanna save some cash so I am leaning on to the GD more
Question is, is the GD still a good buy despite its age?
TIA :-)
Mag paps, need ur help/opinion and advise. Ano po kya problema ng Jazz GD ko, may maingay don sa rear right na gulong pag napadaan sa kahit konti slope lalo na hi-way at kung may passenger sa back. Parang may sumasayad.. Need q tuloy mag menor..
TIA...c",)
it is obvious that a mechanic should see it. dalhin nyo na po sa mekaniko. mahirap magbigay ng payo nang ni hindi man lang nakikita.
but my suspicions include may sumasayad nga.. baka yung wheel well rubber, kung meron.. baka yung rubber bushings ay dapat nang palitan.. baka yung bearing ay pulbos na.. baka yung gulong mismo ay sumasayad na sa katawan!! maraming puede..
good luck.
A little info about Honda's Fully Synthetic Engine Oil
The Layman Auto: What's with 0W-20 synthentic lubricant and will it last?
http://laymanauto.blogspot.com/2014/06/whats-with-0w-20-synthentic-lubricant.html
Manual 1.3
Problems :
1. Experiencing slight jerking when accelerating (unang tapak ng gas) for 1st to 2nd or sometimes 3rd gear.
2. On very long traffic (e.g. idle more than 15 mins) the idling will suddenly increase up to 2+ rpm and
mawala lamig ng aircon. If I turn of the aircon everything will be ok. Need to open again aircon after normal
cruising otherwise babalik uli problem.
Mga sir jazz gd ko napalitan na main oil seal, ni reseal na oil pan at palit top valve gasket pero may nakkita patin ako konting leaks sa ilalim ng car.. Anu kaya un?
oilpan seal... oil drain plug seal..
distributor oil seal (your car does have a distributor, yes?).
main crankshaft oil seals (ugh!).
baka rin, medyo maluwag ang pagkabit ng mga turnilyo..
puede ring butal na lang yan ng natapong langis nung ginawa.. punasan nyo po and see if it leaks again..
Depende sa condition, if the previous owner maingat naman sa kotse,
it still is a good buy, may it be GD or GE, pero syempre, mas okei ang newer GE model.
1. I felt the same before on my GD, its my clutch slipping.
2. pacheck mo nalang sir sa mga A/C shop, usually free estimate naman sila.
best if you have the car underwashed, and observe, malalaman mo na kung saan source ng leak,
flywheel oil seal, crankshaft oil seal, yan yung mga oil seal sa magkabilang side.
or as dr.d's reply, oil drain plug, baka hindi mahigpit
GDs have coil packs already, wala na distributor sir.
Mga ka tsikot, good am.
Related ba sa ignition coil tong na experience ko,
If babyahe ako like short km pa galing sa house namin then once mag s-stop ako either stop light or traffic, biglang mag jolts/kick ung car ko then ung RPM biglang mag random (vibration din; using A/C or not), from 400- 1k, then balik sa dati. Mostly na experience ko to during morning or ung galing pa sa cold engine..
Once makaka ilang km na ako like 20km+, mawawala na ung problem during mag s-stop, pero nakakatrauma
Honda fit surplus 2008 model
salamat ka tsikot- newbie lng po
DONE with TB cleaning - using carb cleaner. Changed new air filter.
New tranny - almost 1 yr used
Sabi ng erpats ko hinaloan daw ng maliit ung CVT fluid ko ng National brand ATF - makaka apekto ba yun?
Newly changed oil and filter (kaso exist pa din ung prob)
