Page 174 of 217 FirstFirst ... 74124164170171172173174175176177178184 ... LastLast
Results 3,461 to 3,480 of 4331
    Jan 2009
    #3461
    Quote Originally Posted by RiMsHoT View Post
    Im not so sure about the broken-in mileage stage. Personally didn't see it in the manual. Maybe 10K kms would be safe enough but don't be afraid to make spirited runs every now and then, kahit na wala pang 10K kms, as long as the engine and tires are up to temp you'll be fine.
    Don't be too sad about the fuel economy indications. The mileage will get better over time.
    Here are some things that might help you (as they do mine. No harm in trying them out):
    - fully synthetic 0w20 SN engine oil, Honda or others
    - setting the tires to 35psi (when cold), 33psi (when warm). If too stiff for you, bawas lang.
    - k&n high flow, reusable filters (cabin and engine). Tried these after purchasing filters from Honda and, for the money, bawing-bawi sa k&n in the long run. Just maintain em every now and then. Honda-marked cabin filter is around P2500, engine around P1300. Ordered from US for 1.5T variant -$45 engine air filter, $40 cabin filter, recharger/cleaning kits $10 for cabin filter, $15 for engine air filter. There are some local sellers with fair pricing also. For the way and where I drive the RS, the stock air filter is almost black-ish everywhere around 3K kms or so, with the 1.8, I think you can do better.
    - changing cvt fluid at 20K kms or earlier, maybe yearly (around P1.8K to P2.1K lang ata sya last time), strictly honda HCF-2.
    - smoother throttling and braking
    - A/C set to 26 or 27 degrees, hanggang maaari. Pero kung naiinitan na kayo, walang magagawa. hahahha. Unless kaya pang bawiin sa higher fan setting.
    - removing unnecessary cargo
    - trying to lose personal weight
    Di ba dapat inflate to around plus 4 Psi when the tire is warm sa recommended pressure? So ang 33 Psi mo na setting when warm magiging 29 Psi na lang yan when cold.
    Mar 2004
    #3462
    +2 psi if you drove for around 30-60 minutes ... +4 psi for long highway driving ...
    Nov 2011
    #3463
    Quote Originally Posted by civicguy View Post
    I see so better kung 2017 model nlng bilhin ko? ano ba ung problem sa eps ng 2016?
    Not really, 2018 sakin may EPS issue sakin since Day 1. But still haven't bothered to process the warranty kase bumabalik din based sa actual feedbacks. Yung iba 3x na nagpapalit, ganun pa din eh.
    Di ko lang sure sa 2019 release, but most likely meron pa din yan ganyang issue
    Baka fixed na dun sa facelfited version (launching this April, together with the Accord).
    Mar 2019
    #3464
    Quote Originally Posted by ironman06 View Post
    From what i've read and heard, lahat ata ng 2016 civis have the same EPS issue. Or maybe the more knowledgeable Civic owners here can shed light? i have the 2018, so far wala pa naman lumalabas, wag din sana lumabas or magkaroon.
    The EPS issue, is yung while turning left or right, may "kumakatok" na parang woodpecker. Noticeable siya, and majority of owners aren't bothere pero if OC ka, then mapapansin mo talaga.
    Other than that, I haven't heard of any other issues with the new Civic.
    Quote Originally Posted by TheUninvited View Post
    I see. aside dun sa noise na prang woodpecker. does it affect the performance of the car? and wala bang ibang masisira if hahayaan lng sya?
    Nov 2011
    #3465
    Affected lang yung steering pag sagad, mostly noticed pag nag papark. May sound and may parang hesitation. Madaming posts sa FB groups if you wanna hear a sample sound.
    Actually ganyan din yung problem ng City GM ko. Hinayaan ko lang, eventually may kalampag na din. (most City GMs have this problem, amazingly the GM6 parang wala akong nababasa)
    My Civic recently lang, nadidinig ko na din may slight kalampag na din. Same sound as my City before.
    Mar 2019
    #3466
    pweding pa sendan ng link ng video? mostly nakikita sa fb nagbebenta lng parts group.
    Nov 2011
    #3467
    Just join any group, I can't send the link since di ka pa member ng FB group.
    Can someone please post the part number for the EPS assembly para sa mga nakapag pa replace na.
    Mar 2015
    #3468
    Guys, whats the recommended offset for 18inch rims to avoid any rubbing? Thanks
    Sent from my BLA-L29 using Tapatalk
    Meron na nagpalit ng keyfob battery? plug and play lng ba? ano battery nito? 27months old ata to..
    Mar 2017
    #3470
    2032, bro. Replaced mine a week ago. Di pa naman dead, I just wanted to make sure. You just have to pry the fob open.
    Feb 2017
    #3471
    Quote Originally Posted by jeddi View Post
    45 off set 235/40/18 stock height, no rubbing
    #3472
    New project:
    #3473
    New project:
    Aha...is that an aftermarket upgrade, sir? A bud got me a used 1 w/ all the buttons. Unblemished & hobo....Grateful![emoji120]
    #3474
    New project:
    dun ako sa relo napatingin [emoji23][emoji1787][emoji3166][emoji3166]
    Quote Originally Posted by AllenR View Post
    did it nadin bro. thanks bro. no more warning. 100 pala ang 2032. maxwell sg nakuha ko. sony indonesia meron din.
    the auto unlock works smoothly. akala ko you need to try the door pa. then it unlocks. now it unlocks completely on the first try. i love this feature
    hmmmm this civic might need the steering rack fix. need to back read.. my photographic memory is a lil rusty lol
    #3476
    Yes, but just for the leather. Having leather wrapped on top of the urethane steering wheel of the 1.8 makes it too thick. So I got this wheel from a fellow Tsikoteer then will just have it rewrapped and will transfer the controls from my original wheel.
    I would've wanted the paddle shifters of the RS as well but as of now there's no locally available TCM update for the transmission of the 1.8 to enable paddle shifters, so I even if I have all the parts and wiring, my transmission can't recognize it so it's a futile exercise.
    That's still my same old daily watch bro. Kakapaservice ko lang in time for the wedding but I haven't bought a new watch in recent history - been pouring my money on the wedding and on home furnishing. [emoji4]
    #3477
    Nice....On the paddle plan, haven't you dug into the paddle harness & compatibility from the previous gen 1.8 instead of that from the RS? Earth Dreams may have a totally different protocol. Just thinking out loud.
    #3478
    Prev gen 1.8 is a 5AT, completely different transmission from mine.
    #3479
    Ahhh...so when & what is the next car then, sir?[emoji4]
    Jan 2017
    #3480
    And just to correct for fun. . . Unless it backfires on me. . .. siguro eh kulang ka pa ng kape sir se
All New 2016 Civic
