Page 74 of 121 FirstFirst ... 246470717273747576777884 ... LastLast
Results 1,461 to 1,480 of 4331
    Sep 2006
    Try the provinces. Bulacan, Laguna, Pampanga,. I got mine in 2 weeks. The orcr? A ridiculous 3mos.
    Sep 2006
    Lame question, what do you do to prevent your civic fc from going autolock everytime you have your car washed by the car wash shop? I wouldn't want to disable the autolock feature everytime I go to the car wash. Is there a workaround?
    vallet mode?
    Jul 2016
    Lagay mo lang susi sa loob
    Sep 2006
    Quote Originally Posted by Janemar View Post
    I hope it wouldn't malfunction though, I mean mag lock sya with the key inside.
    Jul 2016
    Works for me.
    Your call.
    That's part of the car's sensors - if it knows the key is inside the cabin, it will never auto-lock.
    May 2017
    does anyone here experience some kind of engine jerking between 20kph to 35kph especially when you suddenly deaccelerate between those speeds? di naman always nararamdaman pero bothersome minsan. sure ako it’s not because of the rough roads here in manila. kumakalog pa minsan buong body.
    Sep 2006
    Quote Originally Posted by AC_23 View Post
    Haven't experienced this. Hesitation? Or yung feeling na parang hindi optimum yung gear na pinasukan?
    May 2017
    well parang ganun pakiramdam ko on the engine, parang in between shifting sya ng gears at the point when I deaccelerate. ahaha! hirap explain.
    sounds like hindi nag ooff ang injectors? letting go of the accelerator dapat off ang injectors. its just a theory [emoji848]
    May 2017
    i’ll try to mention it to casa rep baka it would help them diagnose the real issue. thanks for the insight.
    Sep 2017
    I feel this too sometimes. Not sure what to tell the casa so they can check when I go for PMS.
    Feels like a rougher engine break then smoothens again.
    Dec 2017
    Re: Engine jerking
    I haven't experienced this yet, but, on the other side of the globe they are experiencing the same issue. Let me get some quotes for you guys:
    "Hi Guys,
    Im getting sick of this, in traffic, 10-20 MPH, when just touching gas pedal, it jerks front and back which is super annoying, feels like not correct torque is delivered from engine or cvt messing up. its 2.0."
    "I think this is pretty normal in my experience. I have the 1.5. try coasting more or accelerating for longer if possible. Tapping the gas pedal is always jerky for me at low speeds."
    "Hello,
    I'm experiencing the same problem with my Civic 1.6 CVT at low speed. I was thinking about poor fuel quality , but the car is still jerking. The car was checked at the dealer, but nothing abnormal was detected by the scanner. I drove a "drive test" car and found it as jerky, but less so. I have asked for a compression test at the next servicing. Hope everything will be fine."
    "I think that is fairly normal, but normally mine is not that noticeable. Just a soft thud of a shift. Now that's when it's normal. From what I know so far the dealership disconnected my battery during the coolant joint recall and my OBDII was reset, for fair warning for those with CVT's it MESSES THEM UP BAD. Shifting was terrible, not highjacking your thread just telling all those with CVT's to make sure they don't (or the dealer doesn't) disconnect the battery without a tender or you are in for serious shifting, bogging, and stuttering issues until it relearns."
    Jerking in low speed traffic | 216+ Honda Civic Forum (1th Gen) - Type R Forum, Si Forum - CivicX.com
    May 2017
    Quote Originally Posted by brushless View Post
    Re: Engine jerking
    "Hi Guys,
    "Hello,
    thanks for this link. during slow acceleration nag-jejerk yung car engine ko but not always. pero if fast acceleration, very seldom. i tried turning off econ, bihira din jerking. dun lang talaga sa slow acceleration + econ on nangyayari. just so weird. i’ll to change gas din on my next 2-3 full tanks baka makatulong. if still recurring, casa na talaga.
    May 2007
    Sharing my Red RS
    May 2017
    Quote Originally Posted by MamBad View Post
    yun nga e. hirap explain talaga. try ko extract video from my dashcam if noticeable yung jerking. will try to visit the casa after holy week, i just hope they can fix it.
    Aug 2016
    Pasali po...
    Experienced this a lot when decelerating my civic rs when it was new, like it's gear-hunting or something .. It is the cvt's belt adjusting or "mating" to its pulley surfaces. I rarely experience it now, especally after doing the first recommended service interval (every 20k kms). What you can try to do is do "manual" downshifting with the lefthand paddle, this helps a lot with reducing the delay when you need the power of a lower "gear ratio" in certain situations. Hope this helps.
    Nov 2017
    Any update regarding this? Have you had it checked?
    May 2017
    Quote Originally Posted by kruser View Post
    I just changed back my gasoline to Petron XCS and the engine jerking has significantly reduced na. Though there are times na bumabalik. Maybe I just have it checked na lang during my 20km PMS.
All New 2016 Civic
