Other than Frankline in examiner, what other reliable repair shop that can do PDR somewhere in QC? my civic got a big dent with few scratches due to parking accident.
I would greatly regret my purchase if standard ang Sensing pati sa 1.8E. Could have waited longer, got my unit last Feb only.
Isipin ko na lang I'll get the first hand experience sa 11th gen since I only plan to keep my FC for 5 years
But I think ilalagay lang ang Sensing sa RS just like the CR-V (totl). The facelifted local HR-V did not get it at all though.
Yeah the 18s look nice, same sa SI, different shade lang.
Nope. Surprising considering the civic's ride height.
Sumasayad dati impreza ko.
Must be the overhangs. [emoji848]
Sent from my SM-G930F using Tapatalk
Driving low cars takes some getting used to. Sweet spots on approach/exit angles & speeds can be familiarized. Our work park space has a steep angle. It also happens to be a favored U-turn slot by the public. I often see different drivers w/ similar cars hit/clear the same area.
If not driver skill, should we say driver weight as variableX perhaps? I'd say both are X&Y.[emoji4]
hello guys, new owner here modern steel. Quick question, does our Civic has a TPMS (tire pressure monitoring system)? or a warning lang if malambot na yung gulong? another thing baka meron sa inyo may user manual in digital form pa share naman, I am looking yung para sa local version natin. thank you.![]()
Yeah wala, as usual stripped down version yung spec atin locally (surprised that we got LED headlights, consolation maybe). I don't know why di pa ni-enable satin, wala naman talagang sensor sa tires, only the ECU computes if abnormally nagbago yung wheel spin/speed via the ABS sensor.hello guys, new owner here modern steel. Quick question, does our Civic has a TPMS (tire pressure monitoring system)? or a warning lang if malambot na yung gulong? another thing baka meron sa inyo may user manual in digital form pa share naman, I am looking yung para sa local version natin. thank you.
Other markets have it though. (not real time, low and high pressure warning lang)
Watch out pala sa EPS ng unit mo, check if you have noise when turning the wheel, especially pag full turn when parking.
my understanding if that is ECU controlled then may way to unlock that feature provided na same ECU rin ang local Civic satin. Thanks for the heads up about the EPS, so in case lumabas yung noise will it be a major issue? or something casa can fixed it on single visit? thank you
EPS will be replaced for free under warranty. But ordering of parts takes about a month.
The car is safe to use even with the noise, so you can still use it while waiting for the parts to arrive. When it does arrive, installation and road testing will take about 1 day.
Already experienced the EPS replaced on our CRV (same problem with the Civic).
