thank you sirs. it already got worse.
the tire was losing air gradually due to built-up residue on the inside of the rims due to dog pee. i thought there was a hole in the tire but there was none. the tire technician had to remove the residue using sandpaper.
i am now thinking of just replacing the rims entirely. any suggestions where to get stock rims that are cheaper than casas?![]()
take a chance on the aftermarket rims shops.
marami kasing nagpapapalit ng kanilang stock rims for other designs, soon after the car leaves the dealer.
try carousell.
but kung isang piraso lang naman, consider having it re-painted.
re-painting mags isn't difficult.
good luck.
^ where's your location?
promaster in qc and masterwheels in las pinas. those 2 i've heard do good work.
What are your other brake pad alternatives? Mine already squealing and need to replace(third time) a new one . I want to go for a change and a bit cheaper than the OEM this time.
medyo matanda na GK natin mga sirs/maams...
any rusting issues?
apart from the known "kulubot" style rust sa mga doors, pansin ko na din sa mga wheel wells ko bottom part near the side skirt line...
8 year old GK here, 92k kms mileage.
Hanggang anong size ng tire kaya ang pwede sa GK RS?
Yung hindi sasayad sa wheel well kahit naka-sagad yung liko.
Yung wala na din babaguhin sa setup, basta isasalpak lang.
Ang size ng stock tires ngayon ay 185/55 r16.
Gusto ko sana ay yung mas mataas kahit konti.
Thanks!
so far wala pang kulot yung stock paint, other than gas gas. wala pa akong nakikitang visible rust sa body. I have removed and cleaned the seats.. so far walang visible rust or evidence of leaks during that process/activity.
sa disc brake, definitely minsan pag naulanan at di nagamit ng matagal, nagkakaron ng rusting, but after few use nawawala naman.. i believe its normal naman.
yung pamumuti ng mga trims is visible, so planning to buy trim restorer na acrylic base (eg. turtle wax graphene stuff), currently using yung old type na turtlewax trim restorer.
7yrs na yung jazz 2016 ko.
