Mga sir, paano po mag lagay ng navigation para sa jazz? T.i..
Sir ardy ty po sa info.
Mga master. Ask ko lang kung ok lang magdownshift pagzigzag daan tas pababa. biglang pagdownshift
Hi guys.has anyone tried increasing the jazz's ground clearance?what possible effect ba if we increase it?
*tedylicious007
SUmasayad ka ba? IMO if you lift it, you will void the warranty on the suspension parts.
Just checked the website of honda philippines, ground clearance for the city, jazz, brio and civic are all the same at 150mm but di naman takaw sayad yung ibang models. Mali kaya ang website?
In pick up truck segment, its measured from the lowest point of the differential, yung "bungo" to the ground, hence the ground clearance measurement. This is as per drawing sa brochure. So, I dont know if there are other definition of ground clearance.
Sa cars, I dont know where they measure it from. My guess is from the lowest? point of the suspension.
Ang bababa na pala ng ground clearance ngayon. Ang alam ko dati 160-185mm ang mga sedan. Ang masaklap nito yung mga humps naman sa atin wala namang standard height kaya sori na lang sa mga naka sedan na kagaya ko.
Ang biruan nga jan eh :
Text ni BF "Hon maglakad/magpedicab ka na lang palabas ng ng subdivision nyo, di kaya ng kotse ko yung humps papunta sa inyo eh."
i do not know, either.
one thought is, the distance between the ground and the lowest point of the ball joint or lower shock mount.
another thought is, the distance between the road surface and the lowest component of the car, which might be the oil sump or the suspension..
and is this measured with the car fully loaded, or with the car empty of passenger?
i dont have any idea whats the basis of getting the ground clearance. As a driver for 33 years, its distance from the body to the ground, unloaded.
*dr. d,
I just copied it sa website nila. No idea from what nila ni-measure yun. So kung unloaded car yung 150mm and then sabihin natin with the driver only tapos sumasayad pa rin siya, could it be the coil springs? Since yun yung nagcocontrol ng rebound ng shocks?
*all... na tse check naman po yun sa 6th mo. pms? if ever may problem sa ilalim? sumayad narin si avvy ko several times sa lubak. i just had my 2nd pms last feb.. & wala naman na mention except na palitan ang ac filter ba yun pero di ko muna pinapalitan.
also saan po kayo nagpakabit ng alarm na hindi ma void ang warranty? tia
