Page 169 of 171 FirstFirst ... 69119159165166167168169170171 LastLast
Results 3,361 to 3,380 of 3406
    Jun 2014
    #3361
    Mga ka GK, tanong lang kung paano tinatanggal yun clip sa cover ng air filter? Sa mga nakita kong videos sa YT tinanggal lang nila yun clip sa right then wiggle the cover loose. Hindi ko matanggal yun cover para ma replace yun filter.
    Sent from my SM-G975F using Tapatalk
    #3362
    Quote Originally Posted by Genspecific View Post
    walang instructions sa owner's manual?
    just looking at the picture, try inserting the flat blade screwdriver to the hole to the left of the metal clamp and turn it 90 degrees to prise the metal rightward.
    my worry is, the metal clip might fall down and hide itself from you.
    Feb 2018
    #3363
    Hindi ko lang po sure sa City GK, but for my Civic FD, walang instructions ng ibang maintenance items sa manual. Nabasa ko lang yung more common items such as Oil change, ATF, bulb changes, etc. Hindi ko nabasa itong air filter hehe
    Jun 2014
    #3364
    Walang instructions on how to replace the air filter sa manual, only how to replace the cabin filter.
    Iniisip ko din gamitan ng screwdriver pero kinakabahan ako na baka ma deform yun clip tapos hindi ko na mabalik.
    Jan 2016
    #3365
    Parehong pareho sa FB except for that which you marked, everything is simply snap on like the one in the right.
    #3366
    maybe someone with experience with it, will chime in later.
    in the meantime, try some exploratory finger maneuvering. it should lessen the danger, compared to using a screwdriver.
    Oct 2013
    #3367
    Mali po yung nakabilog, hindi po yan yung lock. Yung clip is on the other side (right) as seen in the picture
    Jan 2016
    #3368
    Quote Originally Posted by Monte View Post
    Same thought, Hindi ba parang Yan ung hinge at Ang bukas niyan ay sideways
    Jun 2014
    #3369
    Thank you sa lahat mg nag reply. Hindi nya sya inaalis. Dapat pala pataas at palayo ang hila. Kala ko kasi pataas ang hila pagka alis ng clip kaya hindi ko sya maalis.
    Napalitan na din sa wakas ang filter.
    Jan 2020
    #3370
    Ang sakit naman sa bulsa 80k PMS. Parang ayoko na sa casa haha
    Quote Originally Posted by MasterHepburns View Post
    Out of warranty naman na? Go for other shops.. other shops will have correct fluids naman..
    Jan 2020
    #3372
    Wala na sir. I’m planning to do so. Bale di ko pa na ta try sa ibang shop sir. Question konlng, same din ba gagawin na maintenance? Or change oil lang nila?
    Some shops like motech.. they do have a checklist... some shops change oil check leaks yan lng, clean the air filter. You have to ask for the ac filter to be cleaned. Some just dont anything if you dont ask specifically.
    The maintenance checklist is very easy todo naman.. like checking all lights are easy.
    Apr 2014
    #3374
    Good day guys! Ask ko lang, has anyone tried PIAA hyper arros 3900k sa headlight bulb?medyo may hesitation pa ako sa LED replacement and expensive din and baka mahirapan sa driving during rainy season.. thanks!
    Jul 2004
    #3375
    Quote Originally Posted by Augustus 007 View Post
    I installed Philips H4 LED on my wife's GK. Cut off is good, basically mimics the halogen bulb.
    As for the output, definitely better than stock regardless of the road/weather condition.
    I've gone through several bulbs already on this headlight (Stock --> Osram Night Breaker --> Polarg
    Yellow --> PIAA Plasma Ion Yellow) and the LED is definitely brighter.
    If the PIAA Hyper Arros were already available when I got the Philips I might have opted for that
    instead.
    Have been using vehicles with OEM Leds already (LED Projector, Multi-Reflector LED), okay naman as
    long as your windshield tint is not too dark.
    Apr 2014
    #3376
    Quote Originally Posted by glntVR View Post
    instead.
    Thanks po sir sa insights..which philips LED ginamit nyo, un po bang 6000K na ultinon essential po ba? Still on my headlights are the original halogen bulb (Philips longer life ecovision i think). Safe to say po ba na ok sya even during rainy season? As what i have read kasi, those LEDs 5000K and up will be having difficulties during heavy rains due to the reflection of the light or fog? I have no experience yet on using LEDs on the headlights..
    Jul 2004
    #3377
    Yes, that's what I'm using. White box then with the thin heat sink. Got it for around 5.5k or 6k at Roadstar BGC. For me it is okay even during rainy season. Been using
    it for over a year already. Have v-kool medium tint on the windshield.
    For me most important is (1) cut off is maintained so I don't blind other vehicles, (2) I can see better/lights are much brighter than stock.
    Jan 2010
    #3378
    Mga idol, pwede pong humingi ng tips regarding tire and wheel upgrades for 2019 honda jazz, ano po kayang magandang tire size para 16x7 na alloy wheel and offset para mag flush sya sa fender ng stock jazz? Thank you po in advance...
    Aug 2014
    #3379
    Hi folks. Any suggestions or tips on how to clean car rims damaged by dog pee? Napabayaan kasi matagal di nalilinis kotse [emoji852]
    Sent from my SM-N986B using Tapatalk
    #3380
    Quote Originally Posted by enjay72 View Post
    Let it be or refinish, sir.
All new 2014 Honda Jazz (3rd Gen)
