dont buy into ther upsell items (x1r, flush or what have you..)
regular PMS 6mos/10K kms P3K only (0w20 fully synthetic oil, filter, washer and labor), P2700 for cvt oil service 40K kms or 2yrs (hcf-2 and labor). cabin filter and air filter ang magpapa-mahal. buy branded replacement filters for the 2. yan ang gamitin mo regularly, then pag time ng PMS ilagay mo uli yung mga genuine air and cabin filters (clean em, if possible para di nila ipilit na palitan). kung di ako nagkakamali cabin filter is P2500 and air filter is around P1300 or less. but it's still up to you kung follow mo itong peso-saving suggestion ko. I do these, by the way.
any of you experienced failing keyless ignition? yung pag press mo ng start engine (while pressing the brake pedal) hindi nastart ang engine, electronics and accessories lang. intermittent
i went to the typical auto shop for advice. Suggestion nila was directso mag start engine. You have to go through the 3 step process. First push to start electronics (do not press pedal), 2nd push (do not press pedal) to enter accessory mode then 3 push (while pressing the brake pedal) to start engine.
Nagana naman. Yun nga lang i'm not sure if that's the real solution as it the issue is intermittent.
BS advice.any of you experienced failing keyless ignition? yung pag press mo ng start engine (while pressing the brake pedal) hindi nastart ang engine, electronics and accessories lang. intermittent
Anyway, either you're not fully depressing the brake pedal or your push-start button is needing replacement.
Madami sa City GM6 club nagpapalit na, under warranty.
question lang slightly off topic. a cousin just got a 2nd hand 2009 GD 1.5 VTEC. ano ang tamang sparkplug?
we are leaning towards ordinary or at most platinum sparkplugs. i find the iridiums quite expensive even for its touted advantages. thanks
tried searching sa net madami pala klase L15 engine alsoay difference pa ata yin 1.5vtec and 1.5i-vtec
May nagpalit na ba sa inyo ng headlight assembly? Pangit na kasi yung stock ni jazz nababakbak na yung plastic. Looking for suggestions on a reasonably priced replacement. Quote sa casa is 18thou+ [emoji33].
I saw this ad in olx and I am interested to try this. Anyone else got the same? If yes, what is your feedback?
Honda Jazz GK 1419 Headlight Angeleye Projector w DRL Eyeliner n HID, Car Parts & Accessories, Lightings, Horns, and other Electrical Parts and Accessories on Carousell
Sent from my SM-G975F using Tapatalk
What do you guys think of the Honda Jazz 1.5 Sport CVT (Limited Edition)? Is it a good buy? Why or why not? Should I instead lineup to get the RS instead? or Should I wait for the next generation? Thanks
https://www.topgear.com.ph/news/car-...a4354-20190801
Get the manual if you want to get the most out of the engine. But if you don’t like shifting your own gears, get the mazda2...
The Jazz in my opinion is the best in the subcompact segment. Good versatile interior space, easy to park, not that common, pretty simple and reliable, and one of the fastest economy subcompacts, even beating some 2.0L compacts.
However if you value flashy styling and a crap load of features (some are useless), the mazda2 might be better.
If you’re going to get the new jazz, be prepared for some minor issues that needs to be ironed out. That’s the thing with new models, they usually come with new problems.
Honda Jazz 1.5v stock vs EK Civic - YouTube
May kalaban pa na Civic FD. 😂
New???
GK is almost in the end of its life cycle... All new is going to be introduced next month in Japan and maybe coming out next year here in our shores...
The only (significant) issue I know with the GK is with the Starter, which was already sorted out from 2016 model up (as far as I know)...
The rest of the "minor" issues can be considered normal wear and tear in my opinion (like those window/door water leak issues)...
