Hi sirs, i'm just curious as to how is the manual feel of using the paddle shifters of jazz knowing its a cvt. is it not advisable to use these paddles on reguar driving or shiuld i just stick to the jazz m/t model?
Tama nga sabi ng iba dito, kung alam nyo na mostly rough roads ang dinadaanan nyo, why buy a low clearance vehicle in the first place? Dapat nag suv na lang kayo.
whether you will want the car to do the shifting for you, or you want to impose your control over it, is a personal choice.
personally, i let my car do the shifting.
other drivers will want manual override, whereby they feel they can maximize the engine's abilities more..
I usually use the paddle shifters for engine breaking when going down inclines and sometimes drive manually through s-mode when I feel like it.
As for how it feels compared to having an actual gear stick, it is not the same. It feels more like shifting in an arcade style racer. You don't feel the gear changing but you hear the engine Rev going up or down depending. My only gripe with driving s-mode is that gears 1 to 3 are quite close (I only drove a 4 speed m/t owner type jeep before driving the Jazz). It took awhile to get used to it.
Sir napansin ko po na kahit naka-high beam di ganun kalinaw ung stock headlight ng jazz gk. Normal po ba un? Do you recommend changing the headlight to led or will it void warranty. Please recommend sir if may alam kayo na magandang headlight for jazz. Tnx
malinaw ba kapag low beam, at hindi gaanong malinaw kapag high beam? it would seem, your headlight is aimed too high. see if it improves with a lowered aim..
and yes... full front windshield tints are also a source of wonderment to me..
i do hope the projectors are properly reflectored..
if TS has full front windshield tints, i suggest he have it removed first.
increasing the headlight's candlepower because you can't see thru your own tint, is poor judgement. it unfairly limits the oncoming motorists' view on life..
motorists should light the way and announce their presence with their illumination, not blind the minions with their brilliance..
Ask ko lang po kung paano mag watch ng video sa screen? Baka sakaling meron nang naka pag try.
[QUOTE=Genspecific;2517770]Kamusta ang ride?
Newbie driver lang po ako pero sobrang sarap i-drive. Ang bilis mag accelerate pero hindi mo mafi-feel na sobrang bilis mo na pla. I maintain 80-100 kph lang para po safe sa nlex. [emoji23]
Mga bossing, mag ask sana ako kung saan magandang bumili ng rain visor for jazz. tia.
yes that is true, 6 month old jazz, satisfies me a lot, performnce, fuel effeciency etc, but a simple thud on my under chassis causes crack on my trans cover hinimatay ako..
