Page 428 of 442 FirstFirst ... 328378418424425426427428429430431432438 ... LastLast
Results 8,541 to 8,560 of 8838
    #8541
    Quote Originally Posted by Renren123 View Post
    naka-on paps hehe. nagsasalita naman sya pag disconnected sa HU. :D
    Hahaha yun lang, saken may audio naman ang waze if naka pair via BT or naka connect using usb port.
    #8542
    2nd question... di ko mapagana yung mirroring ng phone to head unit (both iOS and Android...) may alam ba kayong way para mapagana ko kahit Waze lang
    Hindi ko pa natry kase for IOS need pa yung lightning adapter to connect it via HDMI
    Jul 2018
    #8543
    baka mali source ko haha. matry nga ulet.
    Dec 2018
    #8544
    Wow bwenas after the warranty.
    Starter dame talaga naka encounter ng problem, dame posted sa HCCP.
    Overhaul? Ano yun? Akala ko lagi replace ang needed.
    Re: Seal yun due to wear and tear?
    Well after two weeks, ayaw nya na magstart. Turns out battery pala problema.
    Overhaul daw as per HC Macapagal is cleaning the starter.
    Yes, wear and tear daw. At 3 years and 4 months, i doubt. Advanced ako sa service and last pms ko before October 2018, inadvance ko na yung cvt fluid.
    #8545
    Quote Originally Posted by KYC View Post
    Hindi naman kasama sa PMS yang checking / maintenance ng starter
    Mukhang yan talaga problema ng mga push start na GM6
    Inaantay ko pa ma-experience. Wag naman sana.
    Sep 2012
    #8546
    Guys, pag na-release na ba yung plaka ng sasakyan, wala na bang kailangan ipabago sa OR/CR?
    #8547
    Quote Originally Posted by vroom2x View Post
    you can ask them if they can put your plaka down on the CR.
    otherwise, "wala na".
    #8548
    Mine is still under financing, original CR is still with the bank. Blank yung plate details.
    By the time ba kukunin ko na and ipapatanggal yung encumbrance tsaka ko na ipa update para reflected na yung plate number aa CR.
    Jul 2011
    #8549
    May warranty ba repaint ng casa? May mga bubbles na lumabas dun sa ilalim ng door handle ngayon ko lang napansin.
    Sent from my SM-G965F using Tapatalk
    Oct 2017
    #8550
    Quote Originally Posted by tobats120 View Post
    6 months if I'm not mistaken. This is at Honda Pasig.
    Sent from my LG-H860 using Tapatalk
    Apr 2015
    #8551
    Just sharing this milestone.... after 5 long years, sinend ko na huling bayad ko sa bangko for my 2014 VX wooohooo! :D 85k+ kilometers ang odo. Nadala na sa Vigan at Abra sa north, Quezon Province sa south. Dalawang beses nakapag Banaue-Sagada-Baguio Loop from Bulacan. Surfing sa La Union at saka sa Baler.
    Anim na beses nahuli ng pulis/mmda. Tatlong beses nabangga, isang beses na nakabangga Naka-isang palit na ng lahat ng gulong. Dalawang beses ang baterya. Pero yung brake pads ko e yun pa rin :P
    Quote Originally Posted by rvn View Post
    congratulatios. brake pads will squeal once they reach the limit notch. when you replace the pads. those caliper pins must also be greased.
    Oct 2017
    #8553
    sir how about push button,,starter,,fan motor nasiraan ba kayo nun? and yung cvtf oil nakapag palit na kayo?
    Apr 2015
    #8554
    Quote Originally Posted by tats25 View Post
    No, hindi nagkaproblema city ko sa mga ganyan *buti na lang* at sana e hindi magkaproblema sa hinaharap. Yung CVTF oil, nagpalit nung ayon sa schedule. Wala ako namiss na maintenance sa Honda Kal. Alam ko sumobra pa nga ako isa, lols.
    Meron kaming 1997 City na nagagamit pa rin ngayon (sira nga lang aircon), so yung City ko e dapat umabot ng 2036, wahahaha.
    Apr 2015
    #8555
    Yun nga, pero baka papalitan ko na before magsummer kahit di pa nasquel. Thanks sa reminder!
    Jul 2017
    #8556
    mga sir ung coolant level ko nasa pinakamababang linya na napansin ng kapatid ko mababa na raw. safe parin ba sya gamitin or kelangan na nya madagdagan? kpag mainit makina nasa gitna ng dalawang linya ung level nya e
    Sent from my RNE-L22 using Tapatalk
    #8557
    Wow 85K hindi ka pa nagpalit ng brake pads? Replaced mine nung 50K na ang mileage
    If you follow PMS sched every 40K KMs or 2 years ang replacement nun CVTF
    push start dame nasiraan hehe wag naman sana tayo masali sa bilang
    Quote Originally Posted by KcireReaver View Post
    Bili ka na lang and top up
    Jul 2017
    #8558
    wala kayang leak?
    #8559
    pag nasa mababang marka na, ay dagdagan nyo, po. nakasaad yata po sa owner's manual yan.
    when engine is hot, coolant expands and overflows to the overflow cannister, which raises the coolant level. this is what you see as "nasa gitna ng dalawang linya".
    Jul 2017
    #8560
    ok doc. nakalimutan ko na ung nabasa ko sa manual kasi. no time to review hehe
2014 Honda City (Gen 4)
