2 15 Mazda 2 - Page 217
More pics<br />
<br />
More pics<br />
<br />
Wow! Very detailed explanation.
Helpful sa mga gusto mag DIY
Kaso not one of those guys that can DIY that
Luckily GM6 has plenty power / cig outlets.
No need to utilize the usb ports. No need to plug/unplug.
Re: wire visibility clean naman yung installation nung dashcam ko, no visible wires.
Yung dashcam ko sa Civic hindi rin nakahardwire, malinis rin naman installation.
Just using of the 12V ports. Yung blue wire lang yung nakalabas (haven't changed it to a less conspicuous black wire hehe), although nasa ilalim naman so hindi halata unless you're viewing it from a low angle:
Yung sa Mazda 3 though nakahardwire yun, just to give it a try. Haven't observed any difference. You only really need to hardwire if you want your dashcam running even if your engine is off. Otherwise, personal preference nalang talaga.
I have the kit already, at yung level ng courage at confidence to install, 10/10 naman. Hehe..
Dashcam currently connected using the cig port sa front. Cables are neat and nicely tucked in din. Need ko lang talaga ma free yung port sa front para sa tv plus.
Personal preference lang talaga.
Yung sa likod mainly for charging phone lang.
Need lang ng info if may nag attempt na sa GM6.
pinagamit ko muna sa sister ko yung 17s mags ko kasi lakas sumabit sa garahe namin ng stock 15s (175/65R15 tires).
Specs: 17x7.5 offset +35
tires: 205/45/R17
may konting rubbing sa likod, kapag puno. pero ang kagandahan, nag increase ang ride height niya ng mga more than 1/2"
kaya kung +42 offset tingin ko no rubbing issue. lalo na kung 40 series tires.
quick question po...
Possible ba na patayin yung radio ng head unit?
Minsan kasi navigation lang kailangan ko and gusto ko sana walang music...
hello guys share lng 2nd time na makabasa ng nasiraan ng transmission, bale sa hcvc group ko to nakita 2014 vx
t2 — imgbb.com
t3 — imgbb.com
t1 — imgbb.com
ang cause daw ung oil cooler seperator nabutas kaya naghalo ung tubig at cvtf oil, napunta sa metal belt ayun kaya daw nadurog at nasira
Guys, compatible ba sa headunit ng GM6, VX 2018 model to be specific, yung Carplay USB dongle?
Pano po malalaman kung kailangan na talagang palitan yung baterya ng sasakyan? Pangalawang beses na po kasi ngayon na ayaw magstart. Yung una po siguro 1 month ago.
