SOHC Engines Vs. DOHC Engines
Difference
SOHC stands for Single Overhead Camshaft. That means that there is only one camshaft per header. Inline engines will contain one camshaft. V-type and/or flat will contain 2 camshafts. For a SOHC engine there are usually 2 valves per cylinder but there can be more with the addition of cams for each valve.
DOHC stands for Double Overhead Camshaft. Now there are 2 camshafts per header. So in an inline there are 2 camshafts because there is only one header, but there is 4 in a V-type or flat engine. These DOHC engines usually have 4 valves. One camshaft for the exhaust valves and the other for the intake valves.
Advantages to having a DOHC engine over a SOHC is that the engine has twice as many intake and exhaust valves as a SOHC motor. This makes the engine run cooler and more smoothly, quietly, and efficiently. But the downfall is that DOHC engines cost more for repairs. To ensure against expensive engine repairs, make sure you change your engine's timing belt about every 60,000 miles.
