thank you sirs for the quick reply. more power!
typically po, in terms of percentages -
re power - example po would you say that DOHC engines are 40% more powerful than DOHC?
re fuel consumption - would you say po that DOHC engines consume 25% more fuel?
kahit po ballpark figures ok na ok na po, para lang may idea kami...
thanks!
SOHC Engines Vs. DOHC Engines
Difference
SOHC stands for Single Overhead Camshaft. That means that there is only one camshaft per header. Inline engines will contain one camshaft. V-type and/or flat will contain 2 camshafts. For a SOHC engine there are usually 2 valves per cylinder but there can be more with the addition of cams for each valve.
DOHC stands for Double Overhead Camshaft. Now there are 2 camshafts per header. So in an inline there are 2 camshafts because there is only one header, but there is 4 in a V-type or flat engine. These DOHC engines usually have 4 valves. One camshaft for the exhaust valves and the other for the intake valves.
Advantages to having a DOHC engine over a SOHC is that the engine has twice as many intake and exhaust valves as a SOHC motor. This makes the engine run cooler and more smoothly, quietly, and efficiently. But the downfall is that DOHC engines cost more for repairs. To ensure against expensive engine repairs, make sure you change your engine's timing belt about every 60,000 miles.
http://www.angelfire.com/hiphop3/ppddaiddddyy/SOHC.html
The difference are two letter......The S and D.
Peace!!! By the way, Ill let someone else do the big answer, here is the short one. SOHC develops a little less power than its DOHC brother, but it develops more of its power earlier and is therefore more flexible and generally more economical. The DOHCs rev much harder and higher, and at mid to top revs develop much more power for the same displacement engine, making them ideal for racing or performance vehicles. And if the DOHC is a V-engine, like a V6 or V8, it could be called a Quad-cam.
SOHC and DOHC simply mean that the SOHC has a Single OverHead Camshaft, while a DOHC means Double OverHead Camshaft. The power and fuel efficiency really depend on what kind of tuning the engines were designed for, because there are cars that have DOHC engines but are meant for fuel economy, while on the other hand there are cars that have SOHC engines that can be tuned for much more power.
In stock form, typically the DOHC will have more power gains due to better control of the valves, since there are two camshafts. More power results in increased fuel consumption, but a better (meaning, lower) overall fuel consumption for DOHC engines can be attained by maximizing the power band and transmission/differential gearing. What this means is, since it has more power on tap, one can easily accelerate to a desired speed with less effort, so less fuel is consumed. But this is primarily dependent on driver skill already.
Also as mentioned earlier, DOHC engines typically have more valves per head, than its corresponding SOHC variant. With that, the DOHC takes full advantage of valve train control to attain optimum power or fuel economy, again this is dependent on the design of the engine.
There are inline engines that have either SOHC or DOHC. On the other hand, there are non-inline engines (either V shaped or boxer engines) that can have either as well. Some V6 engines, for example, have one camshaft per side so the right bank of three cylinders has one camshaft, while the other side has another one. There can also be two camshafts per side, so that effectively makes it four camshafts in total.
