Results 61 to 68 of 68
September 6th, 2006 07:05 PM #61
My regular route is Baguio-Nagulian road with average speed = 40-70 kph only but never attempted to use the Neutral position during downhill, usually used shift position ( D ) =normal to slightly incline road ( 3 ) = incline road about 15 degrees) ( 2 )=more than 30 degrees incline road. Frequently uses engine braking during downhill driving but still I've changed my brake pads at 23K ODO reading.
- May 2006
- 1,668
September 7th, 2006 01:35 AM #62Hmm...maybe you're frequently carrying heavy loads? Might affect the longevity of the pads? Oh well, matipid pala ako sa pads ko.
September 7th, 2006 07:51 AM #63
September 7th, 2006 10:30 PM #64
not my typical dream car " BMW 5 series"... but i love it babeh!
im sure when you press down the gas, youd go
loko. hehehe
Tsikot Member Rank 3
- Nov 2002
- 1,984
September 7th, 2006 11:51 PM #65i shift to N during downhills only if it is safe. I find that doing this makes me get a few kilometers more in my full tank.
- May 2006
- 33
September 10th, 2006 04:57 PM #66Baka OT pero related pa rin sa pag drive ng A/T.
Isang gabi pag start ko ng car di ko maalis sa "P". Tried several times bago ko na shift. Nag storiyahan kami ng anak ko at na experience daw niya ito last month. Pinatay niya ang engine at pag restart nya na shift na niya.
Ng binasa namin ang manual, sabi i-press ang shift release button (it also says to ensure na naka handbrake) pag di ma-shift from "P".
Kaya lang di sinabi bakit ng lock pag minsan.
Mga bro, ano kaya ang reasons bakit na-lock sa "P" minsan? TIA
September 10th, 2006 07:11 PM #67
Usually dapat tapakan yung brakes before you can shift out of park (P) kaya check that the brake switch is working good and yung mechanism ng spring that you press when shifting to any gear is working too. What car is that? Baka luma na and the parts need adjustment/lubrication, etc..
September 10th, 2006 09:52 PM #68Mga bro, ano kaya ang reasons bakit na-lock sa "P" minsan? TIA
1. Driver stops car
2. Driver shifts to P
3. Driver releases footbrake without engaging parking brake
4. As a result, vehicle's weight 'rests' on transmission (because it's in P)
5. When driver returns, starts wondering why it's hard to shift out of P
6. It's hard because the whole weight of the vehicle is resting on the transmission
Engage parking brake before shifting to P . Or at least still have your foot on the brakes after you shift to P so you'd have time to engage the parking brake after.
Replaced with the Pilot Sport 5 na ata, but the available sizes aren't yet as broad as the PS4.
Finding the Best Tire for You
