Results 21 to 30 of 68
September 3rd, 2006 02:20 PM #21
Ako naman hindi pa nakagamit ng tsikot na hindi pwedeng mag N habang tumatakbo...
September 3rd, 2006 03:04 PM #22
what i do i shift to N and hand break pag stoplight na matagal, however pag di naman matagal ang stoplight i just step on the break
September 3rd, 2006 07:05 PM #23
i do that when coming to a halt. pero pag tumaktakbo ka ng normal say, 70kph then nilagay mo sa "N" tapos binalik mo sa "D" minsan parang naco-confuse yung computer ng tranny eh... leading you to a WRONG RPM, or sometimes would GEAR HUNT pag ginawa mo yun.
on a stop, "N" plus handbrake ang practice ko. sometimes "P" lang pero kakatakot pag nabangga ka sa likod...Big time tranny repairs yun mas safer yung former method.
September 3rd, 2006 07:23 PM #24
Not only that, shifting to N while at speed will allow the engine speed to reach idle and when you shift back to D, taas kagad ng RPM. Sira brake bands, clutch packs, and additional wear and tear on your transmission.
When in heavy traffic and you put it to N and pull on hand brake, this creates additional stress on the transmission because some of them have a pump that circulates ATF and when in N, the pump disengages. Hence, it basically heats up (no air passing through radiator either, to cool the ATF fluid).
Only put it to N when pushing the car like when it has a dead battery, this is of course during emergencies only and is done as a last resort.
September 3rd, 2006 09:49 PM #25
September 3rd, 2006 10:07 PM #26
Heto ang keyword diyan:
I also don't know how a transmission can be stressed while at full stop and in neutral because only the vanes (fans) are disengaged and these fans have no cooling function (they are used to transmit engine power hece the turm 'slushbox'). We bench test vehicles and none have failed due to prolong idling in 'N'.
If shifting to 'N' is such a bad idea, I'd have replaced six transmissions already.
But then again, do whatever floats your boat. I'm just speaking from research and real world experience on this one.
Tsikot Member Rank 4
- Jul 2003
- 1,082
September 3rd, 2006 11:25 PM #27ako, i put it in Neutral kung naka stand still and i engage the handbrake para makapahinga yun foot ko... i also put it in N kung wala ako magawa habang mabilis... la lang.
September 4th, 2006 06:56 AM #28
Like Doc Otep mentioned, that's the key. Only some cars have the pump feature on the transmission that disengages when you shift to N and engine is running.
Just follow what your manual recommends. On mine it says that to shift to P when idling in standing traffic. That's why you also often see others turn on the reverse lights when they start moving, kasi nakalagay sila sa P. My mom loves to engage the E-brake and not shift the transmission at all, so nakalagay sa D pero it's not moving. Basically the same thing as stepping on the brake pedal.
Why don't you guys just shift to P para safe? But only do so when standing still! That's what the P is designed for, parking the car. I know that N is much closer, masmadali itulak forward yung lever to get it to N but since you don't know if your car has that pump feature I mentioned, better shift na lang to P. On mine I do know that the pump feature is there, I have an MB 300DT. So I shift to P.
I've already mentioned the dangers of shifting out of D and into N when at speed.
September 4th, 2006 08:13 AM #29
Ako, pag stop and go, I maintain it at 'D'. However, while waiting for the green light or at a standstill,- I normally shift it to 'N', while stepping on the brake or engaging the handbrake.
So far, it works for me...
September 4th, 2006 08:15 AM #30
i don't see why you can conserve momentum when you shift to neutral. for saftey reason, delikado ito coz you are eliminating the traction when you shift to neutral- making the vehicle lighter. even in the manual transmission, shifting from a gear to neutral while the vehicle is moving is a no-no.
