Page 18 of 43 FirstFirst ... 814151617181920212228 ... LastLast
Results 171 to 180 of 425
    #171
    Quote Originally Posted by 17Sphynx17 View Post
    Autosweep wala but I recall Easytrip meron if ADA through Credit Card ang reload.
    Problem is sa Easytrip di nagpapadala ng SOA but I recall they do deduct it. So kung top up mo 1000, 1000 pa din macharge sa card, pero less than 1k papasok sa easytrip mo. I just can't remember the exact value/percentage anymore.
    https://www.easytrip.ph/forms/TermsAndConditions.pdf
    Sa T&C it can be found under 2.1.5 and 2.2.5
    https://www.easytrip.ph/forms/Credit...ority-NLEX.pdf
    Here sa ADA Authority Form, second bullet point under AUTHORIZATION. It also refers back to 2.1.5
    I rechecked to be sure na walang deduct Autosweep, but Easytrip I recall meron kasi nung nagsubmit ako dati ng ADA, isa yun sa "reminder" na sinabi sa akin nung taga Easytrip na staff. But for my convenience di ko na inisip gamitin Gcash or other methods kasi I will most likely forget to reload kasi mas madalang ako gumamit ng Easytrip expressways compared to Autosweep ones.
    Pwede mo makita and maprint SOA from your account in the easytrip website.
    Signature
    #172
    Haba ng pila sa easytrip booth along Shell Edsa across Kaingin kaninang 7am. Siguro 20 cars na nakapila
    Sent from my ONEPLUS A6013 using Tapatalk
    #173
    Para lang tong voters registration. Ilang months nang inannounce, ngayon naghahabol lahat sa last 2 weeks.
    Jan 2008
    #174
    Nung nag announce sila, a few weeks after nag ka ubusan ng rfid sticker... ngayon lang yata dumami stock at minsan nauubusan pa din...
    #175
    Until now under testing pa din daw yung plate mounted rfid. Di ko tuloy magamit yung isa kong car na hindi daw compatible yung sticker rfid nila.
    Signature
    #176
    Walang magawa, bored, so tripping kami ni esmi sa nlex.
    Kanina i temporarily afixed the nlex rfid with scotch tape, located it at the upper right hand corner of the windshield, just about 1 inch below the conduction sticker. Passed thru mindanao toll gate and sta rita exit without a hitch. When i entered sta rita headed south the sensor could not read it. The guard came, atras abante to no avail. I was tempted to undo the scotch tape (both ends were folded for easy removal) but guard came back already with a ticket, sabi sa akin no problem daw pass lang ako rfid toll sa bocaue. Ok naman din sa sensor sa bocaue. So meron talaga silang mga sensors na mahina kasi sa sta rita may mga nauna din sa akin na hindi madetect ang rfid.
    I will cut a window na sa tint. Pwede naman pala sa itaas instead na sa baba ng windshield.
    Jan 2008
    #177
    sana mag offer din sila ng prepaid cards na pwedeng bilhin para dun sa very occassional lang dumaan ng tollway.. pwede naman mag lagay ng QR scanner sa booth mismo.. tatapat lang ng driver yung card
    nag titipid yata sila sa hardware eh..
    Sep 2010
    #178
    #179
    I think to do away with toll booths completely or anywhere where a car has to stop completely to be "scanned" to make the expressways more free flowing, which is ideal nga naman.
    Kaso bulok talaga yung scanners, hindi consistent.
    Once na nag full RFID Implementation sila, di ko alam panu din nga kasi sigurado uulan ng complaints yan sa mali ng debit na panay "end to end" ang deduct kesyo di nascan maayos sa point of origin kaya dinededuct ng max possible sa exit.
    At since free flow na, wala na din yung mechanical barrier na akyat baba diba? kasi suspended na lang yung scanners above the road. Kung ganun na tulad ng ibang bansa, no way to check or know na nascan ka talaga at entry point to expressway. So good luck na lang sa atin na naayos na nila at lumakas na scanners nila (Wishful thinking)
    #180
    is it possible,
    the tags are designed to be installed onto tint-less front windshields?
    ...that problems sometimes arise because they are installed under different conditions?
NLEX EC Tag Concerns
