How exactly do you install these springs? Are you able to determine the measurement of lowerage?
Most original lowering springs will state the estimated amount of lowering. Usually it's around 1" to 1 1/2", but this differs depending on the condition of your shocks and your stock wheel sizes.![]()
Very easy.you have mcpherson strut.REmove 3 nuts on top(under the hood)1 big bolt on the bottom.Once you remove the strut assembly.You need a coil spring compressor,ofcourse to compress your coil spring.once you compress the spring remove the 1 nut on top of the strut assembly.
Your stock shock(strut) will not last because it will work twice to compensate for the lower spring.So it's recommended to replace your shocks with sports shocks.Get H&R spring or tanabe.If you want the lowest drop get the sprint.
Ok, I see..
I think I'll have to prioritize the front and rear bumpers for now since it gives the biggest impact on the car's overall exterior look. I'm deciding between the Type R look or the SIR bumpers. Any other brands worth looking for?
i'd stick with the OEM look. i just loathe all those outrageous body kits out there, especially for civics which are very bountiful. just my 2c bro.
if you want to hear my 2 cents. Save some money and buy a SSR or work rims and slammed that bad boy.
What is an "OEM" and an "SSR"? Please enlighten me with those terms.
Also, how much is a complate washover? I'm thinking of repainting the hatchie with a sporty color except white and black.
If you don't have coil spring compressor compress spring by jacking up vehicle under suspension arm (to compress suspension).
Then use wire (alambre) and tie up the compressed spring. Jack up vehicle under frame and release jack from under suspension to relieve stress on spring.
Finish! hehehe.
But I'd stay with the clean/stock look. Wala ka nang makikitang ganun. Karamihan ng EK parang eroplano na, eh.
Simple lang:
Tipong seseryosohin sa daan. Hindi parang kotse ng bata.
Astig nga yung simple, pero gusto ko naman kahit konting "oomph" lng.
Sir alam mo ba kung ano yung "OEM" at "SSR" na sinasabi nila?
OEM - Original Equipment Manufacturer (Actually, dapat OME...), means looks like it came that way from the dealership.
SSR - brand of aftermarket wheels.
By the way, that picture up there? That's sort of like what the SiR bumper looks like, except there are foglights with plastic housings in that side vent.![]()
please please please go JDM style, and OEM as well, please don't go with nasty bumpers and sides, please don't be a ricer, please don't get 17" chrome rims, 15" would look perfect on an EK, please don't do what you see in the Fast and the Furious movies, BE race inspired <--- no body kits no big wheels . . . first I would lose the moldings, get a CTR bumper with the lip, CTR sides and rear lip...
It is safe to do that as long as you be careful... if you think you can do it, then go do it, if you're having second thoughts it might hurt you or something then don't... There are ways to make them "ghetto style" safe, if you are a resourceful person you would know that... I have done this using ropes (lubid) on my BMW when Autozone didn't have a spring compressor available for a free-loan... Me and my friend also did the same thing to his Evo 9... Damn, not everyone has necessary tool access, and why is it that the car involved being a mercedes an exception??? 'Cause it's a Mercedes?
I salute you.You have balls to remove your Bmw's coil spring without using the right spring compressor and the fact you use a lubid(worst than wire) to compress the springs.Next time try to remove a mercedes coil spring and you'll see what i mean.Just be careful those spring rates are much higher.If your lubid brakes and god forbid the springs hits you,You're goin to feel like thisBe careful.Be safe.Somebody loves you.
Welcome to the [third] world of ghetto repairs. hehehe. A compressor would have been safer. Too bad the shop didn't have any. Working in a garage (instead of the side of a busy main road) would have been safer, too.
And you should see the 'ghetto' stuff we have to do to patients (for lack of funding/proper equipment).![]()
We did have one problem with wire, we couldn't take it off afterwards because it was too tightly wound. We used around 5 layers (intertwined) on four sides of the spring.
First off, thread subject isn't a Mercedes, second, even if it was, would it really make that much of a difference??? I am not sure what the spring rates are on Mercedes, but I am certain that they aren't the same on all Mercedes as you have made the sound of a claim...
I don't think I'd try using "lubid" again the next time I'd have to swap springs. It just happened that a spring compressor wasn't available at the time when I was desperately wanting to do the job... Also, springs won't jump on you IF the rope ever breaks, you would obviously face the top of the strut hats towards the direction to an open space so nobody gets hurt... At first we thought it would fire the strut hat but then it only flew ~5'... I did the rope securely...
I also highly doubt that it would be much of a trouble if you ghetto Mercedes springs, they're "luxury", unless you're talking about one in their sports line, and thus they should have... just ~not too low not too high spring rates, depending on the dampening force provided by the shocks... Ride an Evo 9 on stock suspension and you'll feel how stiff they're springs are right away, since the car's built as a street/track car... I don't know what kind of springs Mercedes put but on my BMW I put progressive springs, which makes it not so hard to compress it with ropes (just tie it around and there's aero chance they'll break)... I swapped springs from OEM to H&R sports (280F/380R), then swapped to H&R race (345F/515R)...
