Originally Posted by
niky
*ronald_m: Dude, you need to chill.
It's common knowledge by now that you live in the US, yes, you might have a fast car, and that things are different there.
The rope or wire-binding method of dismounting coil springs is not ideal, but it's the best you can do sometimes given the level of equipment we have in most garages here in the Philippines.
I've seen it done. I prefer the compressor method myself... but it's laughable to think that you could seriously injure yourself on bound springs.
Before you think we're going all bohemian on you, think about it... when you bind springs, you bind them at the amount of compression that you get with the car on a jackstand. That's with the spring at something like 50% compression. If the rope gives, it gives gradually, and the spring bounces back. It's possible to get a bruise if it hits you, but it's not as bad as if you've got the spring compressed 100% and you cut the ties all at once. You have the rope or wire wrapped multiple times and in multiple places. THis isn't like making one loop and tying it together like a shoe lace. In fact, it's hard to unbind the sucker when you're putting it back in.
In fact, for safety's sake, some mechanics use ropes or wire to bind the springs even when using a compressor, just to make sure it doesn't accidentally slip out.
Hot rodders used to do it that way. It's relatively safe... well, as safe as anything can be when you're working under a jacked up car. But hell, I've seen cases where even hydraulic lifts fail (thank God it was just one side...), so nothing is 100% sure.
And this is the second time that I've seen you call out somebody on what they know. And this is seriously not cool. We here at tsikot are here to try and help other tsikoteers and motorists with their problems. If you don't like the advice, state it, but don't turn it personal... and don't try to make out like you're better than them because of your background.
Now, really... chill.
