Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 68
    #21
    Ford escort cosworth edition!
    Jan 2003
    #22
    A Kia Picanto with a turbo charged engine.
    And you can call it PicantoT
    #23
    para sa akin ang isang sleeper car talaga, ang simple pero halimaw na sasakyan ni manong taxi driver : Hyundai Accent CRDi
    May 2010
    #24
    How much of a "sleeper" do you want? ... factory stock or modified?
    Sleeper cars are usually modified internally while externally is usually left untouched.
    Example, Nissan Sentra Super Saloon with a SR20DET motor producing over 210hp, coil-over suspension set to stock height and 15" stock Nissan wheels with ADVAN tires.
    stock ones. like Lancer EX.?
    May 2010
    #25
    i've seen 2 old kia prides with FORD Badge and Fiesta Badges at Q.ave. stopped for the red light.... at green. started to run fast and sound like a 4age and the other one has a turbo. maybe 4efte? (not surely but sounded like a toyota roar)
    natulala lang ako after nun. state of shock ika nga.
    May 2010
    #26
    It is a problem of design and materials used. Stock.
    The motor can have oil starvation issues when driven at high rpms resulting in the motor self-destructing if maintained for longer than a couple of minutes.
    Tranny issues have it's roots in the "soft" metals used in the gears. Accelerated wear & tear can be seen on the gears.
    literal na sleeper nga... Matutulog na yung kotse. hehehe
    May 2010
    #27
    Quote Originally Posted by 170kphlang View Post
    +1. a good example of a stock sleeper car. aside of the heavy footed driver.
    #28
    Quote Originally Posted by mikomac View Post
    Tama!
    Apr 2009
    #29
    Most likely you read them wrong, must be Ford Festiva, which shares the same chassis and almost similar body with the Kia Pride and Mazda 121.
    I understand identifying turbocharged engines by hearing the blow off (even non-turbos may have them), but how would you specifically know a Toyota roar?
    Most of those sleeper Kias and Charades I know have Mazda and Ford engines ... and one with an SR20DE.
    #30
    Yes, but the Lancer EX looks pretty aggressive as stock.
    Take my EX as an example. Externally it looks pretty much like a stock Lancer EX GLS except for the 18 inch EX-GTA wheels. Under the skin, the suspension was already upgraded with coil-overs & adjustable shocks, the engine tuned with piggyback ECU, drop-in airfilter and performance headers. The ride height is only slightly lower than stock to retain a stock-like look.
    Other Lancer EX units have had more extensive upgrades including turbochargers resulting in over 200hp.
Give me names of a sleeper car
