Results 21 to 29 of 29
FrankDrebin GuestAugust 3rd, 2006 01:31 PM #21
Originally Posted by Helios
"And some things that should not have been forgotten were lost. History became legend, legend became myth
and for two and a half thousand years, the Ring passed out of all knowledge. Until, when chance came, it ensnared a new
bearer."
- Apr 2006
- 85
August 3rd, 2006 01:56 PM #24May kaibigan akong nag stall yung civic nya sa Buendia due to floods. Ang ginawa nya, pilit pinastart yung engine while still in deep waters. Resulta? Overhaul yung engine nya...So i suppose ang problema ay hindi yung umaandar ang engine habang nasa baha kundi yung i-start uli pag namatay. The theory is papasok yung tubig sa muffler kasi the heat of the engine causes vacuum effect. Hihigop talaga yun. Try a to insert a lighted match sa isang empty bottle and cover it immediately, hihigop yun dahil sa flames that burns out the oxygen.
FrankDrebin GuestAugust 3rd, 2006 02:02 PM #25
Originally Posted by Innoko
Hehehe. Sa higlander nilalagyan ko pa ng tubig at sabon ang buong exhaust mula sa headers. Hindi naman sumasabog.
August 3rd, 2006 02:06 PM #26
Tama nga... doesn't matter whether you run it, start or whatever, as long as the air intake is above the water level (and wave level), you're relatively safe.
- Oct 2004
- 278
August 3rd, 2006 10:10 PM #27Originally Posted by Innoko
Paano pa kaya pag turbo? The turbine fins simply cannot spin backwards while there is pressure on the manifold spinning it....
Yung sa friend mo, di sa exhaust, but sa intake pumasok ang flood water....and that caused the hydrolock....
August 3rd, 2006 10:48 PM #28
Di papasok ang tubig sa tambutso, yung Civic ng friend mo pinasukan through the intake malamang since the intake of Civics (the start of the tube) is quite low. Sucking in water will instantly kill an engine if you try to RESTART it.
August 4th, 2006 11:42 PM #29
No clutch. Kapag na-contaminate ng tubig ang clutch dahil sa kakagagamit mo underwater, hindi maganda ang resulta.
Better get the diesel po instead of gas version. Aside from better FC, medyo mas less headache...
Kia Sportage 2014, worth it?
