Page 303 of 389 FirstFirst ... 203253293299300301302303304305306307313353 ... LastLast
Results 6,041 to 6,060 of 7777
    #6041
    Quote Originally Posted by eido View Post
    ano yung considered normal driving or heavy duty driving?
    heavy duty = offroad, towing a trailer, daily stop and go heavy traffic (so i guess if you traverse the metropolis daily that will count), mountain roads even if paved, fully loaded daily. yung paminsan-minsan does not count, like when natratrapik ka lang pag coding ka and you go home at 7pm.
    May 2007
    #6042
    thanks!
    too short
    #6043
    Ask ko lang sa mga naka-2017 dyan na SYNC3 w/ navi ano yung lumalabas sa home screen ng HU ninyo compass or yung map mismo? I was browsing kasi our manual na kapag may navi dapat yung map ang nalabas sa home screen pero sa Eve ko yung compass lang kasi ang nasa home screen kahit w/ navi ang SYNC 3 ko. TIA po.
    May 2007
    #6044
    Quote Originally Posted by Kosmik View Post
    compass sa akin. kelangan ko pumunta sa navi para makita map.
    san pwede mag hanap ng part number ng parts ng everest? pwede ba bumili ng oem tpms tapos activate tpms sa sync 3?
    #6045
    Thanks sa reply po Sir! Nabasa ko kasi sa manual natin kanina na if may Navi ang unit, sa home screen map ang nalabas instead dun sa compass so medyo nagtaka lang ako bakit sa unit ko compass nga ang nasa home screen. Anyway thanks po.
    Sep 2016
    #6046
    Hi guys, hingi lng ako advice kung ano maganda na tint for eve, vkool oem 20 on front windshield oem 05 wrap around or vkool oem 20 front and rear windshield oem 05 on sides, thanks po sa suggestions.
    Feb 2003
    #6047
    Thanks Janemar...saved ko na sa My Fav ang link..was reading it last night and ready to try sa morning but guess the glitch was corrected after almost 2days in parking.. Oks na sya kaya happy na ulet readyfor the trip back home Will look for the Fuse# and dun na lang me mag hard reboot kesa sa batt terminal if me maging isue s Synch 2
    Mar 2004
    #6048
    and they do not recommend using engine flush!!! pakita nyo yan sa sa nyo sa next pm. puro sila engine flush e di pala recommended ng ford.
    Ford PH knows that ... they don't do engine flush here ... they just charge you for the service and materials ...
    Mar 2004
    #6049
    Long idling like when you're always in traffic ... dusty environment like in most of the places here ... frequent short trips (5-8 kms or less) ...
    Jun 2011
    #6050
    IMO.. heavy duty means, Racing, towing at least 70% of its rated capacity and 4x4 off roading.
    Traffic and long idling periods is considered light load... unless, if your total Running hours exceeded 500 running hours or up to 15000 kms.
    Dusty condition... hindi pa considered dusty ang Metro manila traffic... Dusty if you operating sa quarry or mine sites... or un paved roads- or the likes... pag ganyan dusty condition... recommended every week ang air filter cleaning...
    I think the best guage on normal and heavy duty driving is, 15000 kms or 500 running hours... or 1 year... w/c ever comes first... hindi naman na dedegrade ang oil even after a year..
    Sa kabilang banda... change oil every 9 months at mura lang naman ang oil... and also replaced air filters... or clean every week pag dusty condition.
    Jun 2011
    #6051
    I dont find short driving in traffic- 5-8kms to be considered heavy duty.. it gives no stress sa engines nyan... may times pa nga... at 5kms. Travel.. Possibke na hidi mo pa ma reach ang normal engine temp.... it only means... no or little engine stress... light lang yan... unless nalang if it took you several hours to traverse a 5 km. Distance.
    Sa fuel palang consumed, in 5-8kms.. only 1 liter of diesel... baliwala po yan sa engine.... not even near medium to heavy duty driving.
    #6052
    Sa Isuzu owner manual, severe driving conditions are defined as 1) repeated short trips ... 2) rough or dusty road driving .... 3) cold weather driving ... 4) driving on salted roads ... 5) towing trailer or climbing mountain roads frequently
    May 2007
    #6053
    anybody tried telling ford that engine flush is not applicable to eveveres?
    san makakuha ng part numbers ng ford?
    Mar 2004
    #6054
    Frequent short trips and idling a lot are described in operating manuals as severe driving condition ... it should be described as severe driving condition instead of heavy duty driving ... most of Metro Manila is considered as dusty environment ... simplest way to find out is leave your vehicle parked outside and observe how much dust accumulates ... though there are areas that are much cleaner like Makati and BGC ...
    Jul 2016
    #6055
    Let's break it down.
    1. Daily short distance driving(under 10k or 10mins or so) - engine load is minimal(correct) BUT at this point, rich ang af mixture and some fuel will mix with your oil via pcv or blowby sa rings. Include mo na water vapor trapped overnyt sa engine and all of this will contaminate your oil. A good counter is to drive your car longer say once a week para mag evaporate other contaminants sa oil.
    Minsan sa racing, pag nagtitipid. We use 1500per liter worth of racing oil kasi x 5liters or so, it is recommended na you heat the oil upto 150c to boil off contaminants so you can again reuse your 100% synthetic race oil. Same logic when you drive long distances and engine oil heats up...
    2. Dusty areas as mentioned is ung rough roads na pag may kasabayan ka na oto sa harap mo maalikabok or mausok na. However, kahit you live in greenland and malinis ang paligid. LoL. Kung di mo naman nililinis air filter mo at asa ka lang sa casa every 6months PMS. #alamnathis barado din yan malamng air filter mo at considered severe na rin.. Hehe.. 3 plastic clips lang naman ang need tangalin para ma access air filter ng mga everest natin. Wala pang 20seconds matangal at baklas mo na yun. Then pahanginan mo na lang sa gas station, vulcanizing shop or sa bahay using vacuum cleaner blower side.
    Jun 2011
    #6056
    A car running at idle 900rpm will definitely have less wear and tearn against an engine running at 2500rpm..... wala kasing load... or little load...
    Even on idle, your car will sooner or later will reach its normal operating temperature.... Better combustion and oil circulation etc.
    Kahit na siguro we do a test one car will run on idle 900rpm for 10,000 Running hours.. against a car running cont. At 2500rpm for 10,000 running hours..
    Logically, after the test yung naka idle.. is still like bnew... yung running naman for 2500rpm will have major repairs na... reasons .. the higher the rpm the higher the stress on the engine... more fuel will be consumed means more carbon will be accumulated... more Fuel consumed means more fuel burned and heat will make your engine deteriorate faster...
    Yung mga super heavy duty engines... ang RPM lang nasa 900rpm meron pa nga 420rpm..... mas mabagal tumakbo mas less ang load... lesser load will have longer engine life.
    Importante lang the engine will Reach its normal operating temperature for better combustion...
    Yung mga motor cycle... rpm nyan umaabot pa ata ng 12000 kaya madali din masira...
    #6057
    ^^^ so bakit lahat ng heavy duty engine manuals na nabasa ko (emd, caterpillar, deteoit diesel, cummins, wartsila) sabi e avoid running on idle for long periods ???
    and, experience tells me otherwise. my engines on the rigs have more carbon deposits running on idle than on full power. lalo na ang emd at detroit diesel. lagi kaya sama ng loob ng motormen ko pag naka-idle ng matagal yung emd (dc-dc power) at di siya payagan i-off ng driller kasi pahirapan maglinis ng carbon sa intake manifold. part yun ng 800H pm nya kasi.
    Jun 2011
    #6058
    Hindi kasi na rereach ang normal operating temp... kaya hindi maganda ang combustion... para ma reach it needs to be loaded at least 30% of its rated capacity... steady lang ang rpm... kaya pag walang load.. madaming unburned fuel... may min. Amount of fuel lang kasi kayang ilabas ng noozles nya... yung min. Na yun at 400kw nasa 10-15 liters per hour na...
    Ang destroit kung tawagin namin... GRABE talaga accumulation ng carbon nyan... pati oil leak... kaya nga discountinued na production nyan paps... it wont even pass emmission standards...
    Iba naman sa automotive engines variable ang speed or rpm... and kahit on idle it can reach normal operating temperature... per hr. On idle more or less 1.2 li. Lang per hour... nasusunog din mabuti yun...
    May 2007
    #6059
    ano recommended na interval sa pag linis ng air filter? monthly or weekly?
    Jul 2016
    #6060
    Ok. Let's wrap this up na.
    If your daily commute say is from qc going to subic and back to qc daily. Tipong cruising at 80-120kph wherein very little load sa engine at minimal trapik, go for 15k kms pms.
    If you commute from las pinas going to qc and back to las pinas daily wherein trapik ka lagi. Go for 7.5k kms. Pms.
    Anything in between, tansahin mo na lang kaya safe na rin ung 10k kms ni casa.
    Regarding sa filter, start doing it daily. Again 20sec lang naman. Then, after nun, if kita mo malinis pa naman, do it weekly and then monthly na lang. - Ikaw rin mismo ang makaka gawa ng sarili mong maintenance depende kasi yan sa driving conditions mo.
    On my case, monthly ako sabay ko sa pag linis ng cabin filter and charge ng battery. May special case lang na pag napadaan sa bundok na rough road minsan di maiwasan nakatutok ako sa likod ng truck zero visibility talaga dahil sa kapal ng alikabok, dun pag uwi bahay linis agad filter. Sa manila ata malabo naman may ganyan.
Ford Everest 2015
