Page 86 of 359 FirstFirst ... 367682838485868788899096136186 ... LastLast
Results 1,701 to 1,720 of 7178
    Feb 2012
    #1701
    Quote Originally Posted by LexySalazar View Post
    Ako rin from full stop tapos going to 2nd gear may naririnig akong tunog sa ilalim halos ramdam ko pa sa accelerator. medyo mabagal pa yong pagpalit ng gear lalo na sa 4th, 5th & 6th gear inaabot ako ng 2300 to 2400 rpm bago magpalit ang gear. Ginagamit ko yong manual mode nya para lang makapag shift agad ako ng gear.
    I thought most A/T shifts at 2500 rpm, at least it did with the other vehicles I've driven.
    Sep 2012
    #1702
    Quote Originally Posted by edtf View Post
    What is the periodic maintenance schedule of the ranger? (every 5k?) Ave cost of service?
    1st check is 1k, 2nd is 10k then every 10k onwards. Ave cost is 8k labor and material.
    Sep 2012
    #1703
    Quote Originally Posted by taraki17a View Post
    ibig sabihin 80 centavos per kilometer ang halaga for PMS.
    Aug 2011
    #1704
    Quote Originally Posted by A-OK View Post
    Oops my mistake. U r right, TJ. Thanks for the correction.
    I Googled Mt82. It listed some problems in mustang like difficulty in shifting. I've noticed the same in ranger. It causes delays in shifting. Will ask dealer if they have Technical Service Bulletin to correct it.
    Your most welcome sir. Im worried also since all of these are new technologies of ford and inmo they are not proven to perform well. I experienced this in my ford fiesta as it uses dct. Dct is basically a manual transmission with actuators and sensors to do the part Of the driver and what is complicated here is the calibration oh ECU which ofcourse not serviceable part.nasa developmental stage pa ito. Halos maubos ang gas ko kaka- program ng ford service ang ECU ko. They need to test the unit in high speed and Then recalibrate. My regrets is up to now hindi pa rin nawawala ung shifting problem ng fofi ko (a/t). I hope minor mechanical problem lang sa ranger
    Aug 2011
    #1705
    Quote Originally Posted by PentelPen View Post
    Well i hope recalibration lng ito
    Aug 2012
    #1706
    Sa nissan navara hindi naman sa 2000 rpm shift na agad ang gear kaya nga pansin ko mas matipid pa sa diesel kahit na mas malaki ang engine ng navara. Pero hindi ko lang alam sa manual ito po ay sa automatic lang. Puro pick-up kasi gamit namin ng mga kaibigan at mag kakaiba kami ng model kaya lagi namin napag uusapan kung ano ang pagkakaiba ng mga unit namin. Okay naman sa akin yong blue ranger ko maliban sa medyo malakas sa diesel at mabagal ang shifting ng gear.
    Oct 2008
    #1707
    tsk tsk,... buti na lang mag bago isip ko... m/t kinuha ko
    Feb 2007
    #1708
    M/t yung blue power ranger ko. 8.1 Liters per 100km.
    So it will be 12.3km per liter but its a inboard computer computation by the ranger(dont know if its accurate) Havnt tried manual computation.
    Long drive ito. Meron stop and go maybe around 5stops, and carrying some containers containing diesel around 74liters
    Sep 2012
    #1709
    Quote Originally Posted by sparcom2 View Post
    yes, at the least 80centavos per 1km, pero consider also price increases this coming years sa labor and/or materials. also, every 30k km yung change air filter, i think.
    #1710
    Thanks!!! Studying cost of vehicle and also cost to maintain
    Sep 2012
    #1711
    Quote Originally Posted by ersatz0906 View Post
    just would like to share also my rough computation on my FC when i last travel baguio - makati - baguio.
    total distance traveled was ~582kms
    full tank from full tank at the same pump cost me 2035 pesos * 43.3 pesos / Li = ~47 Liters
    FC then is around 12.38 km per Liter or around 8.1 Li / 100km
    which is in consistent with sir ersatz0906 's FC.
    drive style was more on the aggressive mode, 1 passenger half way, 3 passengers the 2nd half, + the 30kg x 2 sack of gravel i tied on the bed; so eco driving mode at the highway will definitely give us more than 13km per liter.
    Nov 2006
    #1712
    This is a manual as well, correct?
    Hay parang ayaw ko na magwait for the Wildtrak kasi walang M/T. With all the horror stories of A/T ng ford and the high maintenance costs I might just get a manual 2.2.
    Can anyone give me feeback sa M/T transmission? Does it shift smoothly? How does it compare to a hilux m/t? in terms of shifting and ease of use. For the A/T users aside from the sound when changing from 2nd to 3rd what else? Is there a solution? How is the FC?
    Thank you so much!
    Sep 2012
    #1713
    Quote Originally Posted by Cyferion View Post
    Thank you so much!
    yes, Manual transmission. (sorry, i forgot to mention).
    my feedback on MY 2.2 M/T: (notice, MY unit lang ito ha, baka lemon yung transmission ko )
    -i really don't like driving it on a stop-go uphill condition, ang hirap timplahin.
    -my cousin who has more time driving the 3.0 m/t hilux says the transmission of the 2.2 mt is 'high speed' compared to the hilux, the 1st gear of the ranger feels like or drives like the 2nd gear of a 3.0 hilux m/t. not sure what he means, could be that the ranger is less torquey at 1st gear even if compared to the 3.0 hilux at 2nd gear.
    - from my limited experience with the hilux 3.0, parang mas smooth ang gear shifting sa hilux. happened to me many times na, na kung mag kulang sa apak sa clutch, mag gri-grind yung gears shifting from 2nd to 3rd gear. could be drivers fault, pero never ako naganun sa hilux.
    - madali mabitin sa 2nd gear, traffic uphill, kailangan mag down shift sa 1st... basta lower than 1.5k rpm, wala talaga ibubuga na torque.
    question: mas mahirap ba talaga timplahin pag bago ang sasakyan, parang kailangan bang ma break in din mga clutch linings?
    Nov 2006
    #1714
    I see. Thanks for the analysis! I think may break in talaga clutch linings since they wear out din. I think I should test drive the M/T myself though i don't know which dealer has one available for that
    Sent from my GT-N7100 using Tapatalk 2
    Jun 2012
    #1715
    Good day rangers... Share ko lang din po my experience and findings when I was given the chance to test drive your truck (manual tranny)...
    Exterior:
    1. Hands down... No words can describe...
    Interior materials: (Dashboard, seats, etc...)
    1. Sad to say my wife and I are not impressed... It looks cheap compared to dmax (our other option).
    Accessories:
    1. Better... Love the rain sensing wiper, voice control, cruise control, etc... My wife loves the adjustable driver's seat height... Downside no backing sensor...
    Suspension:
    1. Great for pick up... Better than my nissan frontier but almost identical to my navara...
    Power or torque:
    1. High revving truck... The power is on the higher rpm just like my navarra... I have a little bit of problem trying to mix the clutch and engine when i was climbing uphill from full stop... Same thing with my navara.. The reason for this maybe (correct me if i'm wrong) for its high rpm torque... Navara's engine occassionally stalled during low rpm on 2nd gear... For high RPM or long stretch SKY is the LIMIT for both trucks... As for my frontier no problem for climbing from full stop and never stalled the engine on low rpm...
    For comparison I have 4x4 frontier and 4x4 navara...
    Decision:
    Undecided... We have to impress ourselves with the interior materials... As our frontier and navara did... Maybe the 4x4 wildtrack will...
    Nov 2006
    #1716
    Quote Originally Posted by jepoyski101 View Post
    Exterior:
    Accessories:
    Suspension:
    Power or torque:
    Decision:
    Thanks for your analysis!
    I just don't get how you and your wife find the interior of the Ranger cheap? Soft touch most parts ng Ranger compared to the Dmax interior which is all hard plastic (cheaper) na currently in the market. I hope you meant the new incoming Dmax as your other choice because the current one does not compare at all except for it's engine.
    Jun 2012
    #1717
    It's the latest dmax the isuzu has now... We are not impressed dahil cguro we are used to have leather seats for our trucks...
    #1718
    finally the ford ranger is in my garage
    Oct 2008
    #1719
    napansin ko nga naninibago ako pag grandia at grandstarex dala ko...... lalo na sa uphill kailangan yata nakabisado mo timpla ng clutch
    - - - Updated - - -
    napansin ko nga naninibago ako pag grandia at grandstarex dala ko...... lalo na sa uphill kailangan yata nakabisado mo timpla ng clutch ng ranger
    #1720
    Quote Originally Posted by emocjr View Post
    Congrats on your new ranger. Enjoying the ride?
2012 Ford Ranger
