Page 14 of 19 FirstFirst ... 4101112131415161718 ... LastLast
Results 261 to 280 of 366
    Feb 2017
    #261
    bro, eto number niya na nasa akin. try mo tawagan o i message...09175039909
    Thanks bro. Baka madaming messages sa FB niya natabunan na ung akin.
    Sent from my ONEPLUS A5010 using Tapatalk
    Jun 2013
    #262
    Hello and sorry for the noob question.
    Ask ko lang what Zic variant should I use for my sta fe 2013 diesel?
    TIA!
    Quote Originally Posted by yohann9 View Post
    TIA!
    Ano nakalagay sa owners manual? Api-cj4?
    #264
    Zic 5W30 on my 4M41 monty.....super pino
    May 2011
    #265
    Ilan km bago change oil on that oil boss?
    Sent from my SM-G930F using Tapatalk
    #266
    Quote Originally Posted by 3GEMS View Post
    once a year ako or 5K kms
    Apr 2012
    #267
    Wala ba kayo nagiging problem sa 30 weighed oil kahit summer o madalas sa traffic? Tempting to use on nxt oil change [emoji16]
    Sent from my SM-J730G using Tapatalk
    #268
    Wala naman ako issue in using 30 weight oil. In fact, the engine of my cars require 30 weight oil. I use Zic X7 5w30 on my FXT and I will be using the same for my Fiesta's next oil change.
    Apr 2012
    #269
    My starex advised according to the manual 5w30, 10w30 and 15w40
    But kinda hesitant to use 30 weight oil [emoji16]
    Someones encourage me please [emoji16]
    I see 41c temps and my 10w30 semi synth oil is perfectly fine.
    Apr 2012
    #271
    Thanks, Ph weather never reaches 41c i think.. Lol
    May 2011
    #272
    Garage queen na si Monty
    #273
    baka kasi maluma hahaha. hindi, mas masarap kasi mag motor nowadays
    bro the cooling system will handle this easily. there is a thermostat that opens when the coolant reaches 87-91c. this is rather old technology almost like non-inverter air conditioners(on off). the radiator and fan can cool easily an engine that is only idling in traffic thats only around 2kw. and full power around 90kw? thats easy for a properly designed cooling system.
    newer engine cooling systems now have variable speed water pumps(non belt driven) and electronic thermostoats. theyre more like inverter type air conditioners(variable). names like dynamic force from toyota and smart stream from hyundai and kia feature this variable cooling system. this maximizes thermal efficiency and affects fuel consumption.
    Oct 2013
    #275
    I bought an x7 and x9.
    Nakalagay sa likod ng x7 na fully symthetic blend motor oil while nakalagay sa X9 na fully synthetic motor oil.
    Does th8s mean that x7 is a semi synthetic oil?
    Quote Originally Posted by Monte View Post
    yes 🤭
    #277
    Any review on this Brand? OK ba sya?
    Planning to use in our shop but some of my friends telling me pangit daw and our Mechanic Manager ayaw
    Quote Originally Posted by CLAVEL3699 View Post
    Go for it.
    ACEA - C3 5w30 is for
    Fortuners/Hilux Mux/Dmax Terra/Navara Everest/Ranger
    API - SN 5w30 10w40
    for everything else
    Oct 2018
    #279
    i drive a 2013 everest. changed oil to X7, noticed that the engine became noisier and may vibration on idle. actually not sure if its engine oil related, but yung engine supports are ok. ang mga pinalitan lang prior to the issue was change oil and belts
    #280
    I don't know with the experience of others but I have no issues using the X7 on my FXT.
Zic engine oil
