Page 8 of 10 FirstFirst ... 45678910 LastLast
Results 141 to 160 of 199
    Feb 2019
    #141
    I was looking for Hyundai Xteer engine oil online and saw this one "Hyundai Xteer Gasoline G700 5W-30". Is it the same as "Hyundai Xteer Ultra Gasoline Protection 5W-30"?
    #142
    Diba shell ang iniiendorse ng ferarri? Wala na sila ni shell?
    Sent from my SM-S901E using Tsikot Forums mobile app
    Partner pa din sila.
    Shell fuels
    Pennzoil lubricants
    On the topic of higher viscosity engine oil for hotter operating temps:
    Ferrari recommends Pennzoil PlatinumŽ Euro 5W-40 (street use) and Pennzoil PlatinumŽ Racing 10W-60 (racing/track use)
    Sep 2021
    #143
    I have a gallon of this (G700 5W-30) in my stash.
    According to the guy that gave it to me, semi synth. ang G700 (although it reads "synthetic" on the label) .
    The Ultra variant is 100% synthetic.
    Funny thing is G700 is API SP while the Ultra is only API SN.
    Sep 2010
    #144
    Quote Originally Posted by Miles_on View Post
    Ah ok thanks for this! Good to know! Was scouring Lazada & Shopee for 5W-30, those are one my options.
    Feb 2019
    #145
    I see so i will go with Hyundai Xteer Gasoline "Ultra" protection. Do you know of a local reseller? I just ordered in Shopee but I fear that I might not received the item because lately there is a problem with Shopee delivery.
    Jan 2016
    #146
    Here I go again, oil change time! Time flies really, 1 year na agad since I last changed it. Wala pa ata 1k kms tinakbo
    Sep 2016
    #147
    Pwede bang ipagamit yung naipon na extra engine oil from previous PMS? May sobra kasing oil every PMS and lahat ng ginamit during PMS eh inuuwi ko.
    #148
    i do. the engine don't seem to mind.
    basta lang, compatible the oil grade.
    Yes
    Sep 2016
    #150
    Yes
    Thanks! Mabuti na lang pala inipon ko.
    Sep 2021
    #151
    Depende kung gaano katagal since opening the container.
    Engine oils, mahaba shelf life niyan if unopened- as in years.
    Pag opened na, use the remainder within a reasonable* time.
    *I don't have data, authorities, etc. to cite as to how long a "reasonable" time is but IMHO, kahit higpitan mo yung pagsara ulit and keep them in their original containers, they will begin to absorb moisture, etc. Hindi pa rin ideal yun compared to "fresh" oil in bottles sealed from the factory/refinery.
    Palagay ko, if mga 6-12 months from yung last oil change ok lang, but if yung medyo taon na, wag na. What we do with the "butal" remainder oil is to use them to grease hinges of gates, or brushed/wiped (very lightly) on tools in storage, etc. para di naman sayang... or use them for topping up (a little) in between oil changes, pero yung tipong inipon mo until a liter or more na, tapos yun isasalin mo sa engine, wag naman siguro.
    Malamang, yung sobrang oil is from mga midsize engines (1.3 to 1.8) na mga 3.5 litres (inc. filter) ang capacity, tapos gallon container yung binili, so lagi may sobrang mga 400ml or so
    Jan 2016
    #152
    Yan din ang nabasa ko dati about opened containers so sa 1.8 ko, may konting tira nga ang 1 gallon so itatago ko ito just in case kumain ng oil ang engine and I need to top up. But it never happens so I throw away (responsibly) this leftover on my next oil change and keep the butal of the next for the same reason.
    #153
    lalo kun pag top up lang until you get to your next oil chage. pwedeng pwede.
    Sep 2021
    #154
    Pwede rin if marami na yung naipon na sobra, suggestion ko gamitin na lang pang flushing sa makina, before you change the oil.
    Eh di nagamit pa pang linis ng makina di ba?
    Much, much better & safer than using those solvent/dispersant flushing oils (which I personally, don't recommend- my opinion).
    Jan 2016
    #155
    Pwede kaya ang 3 liters pang flush sa ganito? Abot ba sa minimum line ng dipstick?
    Sep 2021
    #156
    Ang generic template is 1 liter yung difference between yung low and full indicator sa dipstick, and may laman naman yung existing oil filter, so 3 liters should be above the minimum line, BUT mahirap magsabi, kasi iba iba na ang mga makina.
    Kung kulang eh di dagdagan na lang konti from yung bago mo na dala pang change oil (tutal lagi naman ata sobra yung 1 gallon) so you have more than you need, and that will solve the problem na may naiiwan
    Feb 2019
    #157
    I recently bought 7Li of engine oil from shopee online. I was surprise when i opened up the package it has oil all over the box so immediately I check all bottles and surprisingly all bottles were sealed properly and no spill coming for the bottles. So how come it has oil all over the box and bubble wrap? I chat with the supplier and they told me their items are all brand new and sealed. I was thinking probably they repack the oil? but it is sealed hmm......
    #158
    i am not saying this is the case with yours pero ang hirap nga alamin if ever fake oil nabili mo as in some of them re use the original packageging. kailanagan mo magkatabi both at buksan para malaman minsan
    Feb 2019
    #159
    I bought it from STC Automoto I check their FB page and they look legit that's why I buy from them.
    Sep 2021
    #160
    i am not saying this is the case with yours pero ang hirap nga alamin if ever fake oil nabili mo as in some of them re use the original packaging. kailanagan mo magkatabi both at buksan para malaman minsan
    Reusing the original containers? Pwede, pero parang ang hirap ata gawin:
    Tipong ganito?
    1.Have people scrounging around/buying from mambobote containers of premium brands- Mitatsu, Eneos, Amsoil, Mobil1, etc.
    2.Have people cleaning/refurb. these used containers para hindi halatang galing sa basura;
    3.Refill container from drum of cheap 20W-40 CD/SF;
    4.Pass off the products as “genuine” Mitatsu 0W-20, etc.
    Problems:
    1. How do you ensure a steady sufficient supply of used containers to sustain operation (para makabuo kahit na 1 box of 1 liter bottles, for example)? Sigurado ako, even if you scour MM daily, hindi consistent ang mabibigay sa iyo (iba iba, gallon, 1 liter etc., and iba ibang brands) (hindi yan bote ng patis etc. na standard etc.) Baka matagal bago ka makaipon ng enough of the same size & brand containers
    2. Ang hirap/tagal linisin (labor intensive) yung mga containers etc to a level na mukang brand new (walang mantsa yung label etc.-remember galing sa basura ito) More likely, mahahalata ng bibili na nilinis lang.
    Given all that needs to be done & yung problems mentioned, I don’t think one can do this on a scale/volume enough to make it profitable.
    One would do all that para makabenta lang ng say, 2-3 boxes per month of fake oil? (and remember, hindi naman lagi may bumibili) Magkano lang kikitain dun, given all the hassle involved? Baka malaki pa expense/effort for chump change lang...
Your car's Engine oil
