Results 11 to 16 of 16
- Sep 2011
- 77
June 13th, 2012 08:40 PM #11
- Sep 2011
- 77
June 15th, 2012 11:06 PM #12I'm quite confused. Dinala ko na sa mekaniko yung sasakyan mga sir. He said that the belts are still good. What we replaced was a bearing. after nun, may sound pa din, he said that it could be the bearing of the alternator or the timing chain. so dinala namin sa tumitingin ng alternator, he said that it is impossible kasi hindi daw tunog bearing. what he did was to adjust the belt. pero meron pa din, so he and another mechanic concluded na parang sa timing chain nga daw nang gagaling yung sound. They quoted it at 6,000 including the labor. Papalitan daw yung timing chain and the lower and upper pulley. When i tried pressing the gas pedal naman kanina , wala namang sound. I need an advice po sana if timing chain na po kaya yung problem kasi it can get worst daw if yun nga ang problema at hindi naayos.
June 26th, 2012 11:16 AM #13
natest mo naman na sir, wala ng sound sabi mo,
no idea sa timing chain thou, wala pa ako nagagamit na auto na timing chain.
tignan mo sir engine bay mo, if may mga rubber scrapings sa parts sa paligid ng mga belts,
probably may belt dyan na nagagasgas which creates the sound,
pwedeng misaligned ang alternator for example.
nung tinetesting nila sir, pinapakinggan mo din?
dapat pag nagtetest sila, tutok ka,
para hindi kung ano-ano ang ibibigay sayong qoute or kung ano mang "sira".
- Jan 2008
- 4,726
June 26th, 2012 11:40 AM #14have you crankshaft pulley checked... there are crankshaft pulleys which are made of 2 parts (drive and pulley) which are separated by rubber damper... if the rubber damper is failing, you will hear squeaky sound even if you tighten the belts...
- Jul 2010
- 570
June 28th, 2012 10:48 AM #15Madalas worn out bearing experienced ko sa ganyan. Lalo na kung may nag adjust sa belt tensioner ng alternator at air compressor na sobra higpit. 3 months lang babalik ka uli sa naghigpit ng belt mo. Kita uli siya. Kaya ako ay set ko sa tension tension para di masira kaagad yun bagong bearing.
- Apr 2018
- 1
April 13th, 2018 03:50 PM #16
Tentative price increase from removal of the pickup tax exemption leaked:
Toyota Hilux (9th Gen)
