first, the noise: change your accessory belts. they are due for replacement in four years or around 100,000 km. the alternator belt is the most possible source of the noise since the alternator is supposedly on duty everytime the engine runs, the p/s belt and the a/c belt only makes noise when they are on duty except when the idler pulleys are stuck.
second, the abs light:it is a separate problem-check the fluid level, cehck the wheel speed sensor and make sure the tires are of the same diameters.
Thank you sir for the help! It turned out na its the fan belt. May mga medyo pro na tumulong sakin. What they did was. To pour water to the belts. And nung inapakan ko ang gas pedal, nawala yung sound. Thanks for the help sir!
