Quote Originally Posted by iamjcesteban View Post
I'm quite confused. Dinala ko na sa mekaniko yung sasakyan mga sir. He said that the belts are still good. What we replaced was a bearing. after nun, may sound pa din, he said that it could be the bearing of the alternator or the timing chain. so dinala namin sa tumitingin ng alternator, he said that it is impossible kasi hindi daw tunog bearing. what he did was to adjust the belt. pero meron pa din, so he and another mechanic concluded na parang sa timing chain nga daw nang gagaling yung sound. They quoted it at 6,000 including the labor. Papalitan daw yung timing chain and the lower and upper pulley. When i tried pressing the gas pedal naman kanina , wala namang sound. I need an advice po sana if timing chain na po kaya yung problem kasi it can get worst daw if yun nga ang problema at hindi naayos.
natest mo naman na sir, wala ng sound sabi mo,
no idea sa timing chain thou, wala pa ako nagagamit na auto na timing chain.
tignan mo sir engine bay mo, if may mga rubber scrapings sa parts sa paligid ng mga belts,
probably may belt dyan na nagagasgas which creates the sound,
pwedeng misaligned ang alternator for example.
nung tinetesting nila sir, pinapakinggan mo din?
dapat pag nagtetest sila, tutok ka,
para hindi kung ano-ano ang ibibigay sayong qoute or kung ano mang "sira".
