Page 3 of 3 FirstFirst 123
Results 41 to 60 of 60
    Quote Originally Posted by dfopiso View Post
    As per owner's manual, let the rpm settle sa normal idling level. During start, >1k rpm tapos bababa about 800 rpm in a few seconds
    Ganyan sa gas engines, sa diesel may 1 minute talaga na ideal warm-up even with a fully functioning thermostat. Mas gusto ng diesel na medyo mainit kunti eh.
    Jul 2012
    #42
    I always warm up the engine ---- I never load the engine until it is in its working temperature.
    Simple as that
    Jun 2007
    #43
    ^^ agree ... 5 mins is too much
    Jun 2007
    #44
    thanks Ry ... im about to ask about diesel engines
    Aug 2011
    #45
    think in wintertime, they warm up the engine also because the engine coolant is used in the HVAC to heat up the passenger cabin. It usually takes a few minutes for the engine to become warm enough to raise the cabin temp.
    Quote Originally Posted by Errol5 View Post
    maybe so, and that is just to help to warm the cabin. but in terms of idle time or waiting for the oil to circulate before driving, any more than 5mins is just a waste of fuel.
    Mahirap magdrive kung nanginginig ka sa lamig. Kaya antay muna uminit cabin.
    Dec 2011
    #46
    Modern engine doesn't need too much time to warm-up, 30 seconds max before driving away:
    "In winter, don't idle a cold engine for more than 30 seconds before driving away."
    Fuel Efficient Driving - Eartheasy.com Solutions for Sustainable Living
    Jun 2007
    #47
    ^ for both petrol and diesel?
    #48
    What's often forgotten is that idling warms only the engine – not the wheel bearings, steering, suspension, transmission and tires. These parts also need to be warmed up, and the only way to do that is to drive the vehicle. Until the engine temperature begins to rise, it's a good idea to avoid high speeds and rapid acceleration.
    #49
    Paano if you're not using the car for at least 3 days?
    Jun 2007
    #50
    ^ sa lumang auto, longer time to warm up ang gawa ko
    Feb 2012
    #51
    sa lumang liteace ko palyado pag hindi na warm up.
    kahit 1to2mins lang na warm up ayos na
    Quote Originally Posted by lexwen View Post
    Same ng post ni Noel. Warm-up engine by at least 1-2 mins. and then drive slowly muna to make sure differentil oil, tranny oil and other mving parts get a good warm-up as well.
    May 2011
    #53
    It's always better to warm the car up vs. not warming the car up. Kahit 2mins lang. - For diesel engines ha. For gas, seconds lang.
    Feb 2009
    #54
    with today's cars, close tolerances between the piston and the cylinder bore, close tolerance between the crankshaft and camshaft bearings, there is no need to warm the engine up. the radiators of yesteryears had three rows of cooling tube versus today's with only one does not need the traditional warmup. it was so designed to save fuel and increase the mpg rating of the car. even the oxygen sensors have shorter time to get to closed loop because of the heating element inside the oxygen sensor itself. parts have been lightened (again for fuel economy) and gets to operating temperature faster. with some purely air cooled engines, the moment the engine runs, it is as warm as operating temperature. the problem though, with the designed short to no warm up time needed, is that the engine overheats if the cooling system is not properly operating: i.e. no thermostat or stuck closed thermostat, radiator cap that can not reach the required pressure, wrong type or wrong mixture of the anti freeze coolant, insufficient airflow to the radiator, air pockets in the cooling system that had not been bled, over advanced ignition timing, clogged exhaust system and vacuum leak at the intake manifold. today's car are made to be driven as soon as the engine starts.
    Oct 2011
    #55
    parang tao din yan eh, bago mag basketball, warm-up at stretching muna.
    #56
    1994 Nissan Vanette Z20S Engine. Local.
    Thermostat was removed by the previous owner as well as yung fan clutch-nakarekta na.
    Every morning, 1-2 minutes of engine warm-up before I drive or else engine will stall.
    Jan 2009
    #57
    As jeck says.
    The one thing you should not do after starting up a cold engine is to race it (ie. aggressive throttling, acceleration and/or red-lining). Otherwise, you can drive the car as you normally would.
    If we're going to use an athlete's body as an analogy, a warm-up exercise means running a lap or two around the court, doing jumping jacks, etc. You don't warm-up just sitting down doing nothing. Somewhat the same with cars. You warm it up by "stretching its legs" and just be on your way.
    Aug 2012
    #58
    what i do for my mb100 is to idle it for 1-2 mins then slowly drive it off
    Oct 2011
    #59
    right on the button.
    Jul 2011
    #60
    ae101 ko, 30 - 40 seconds,
    para lang umikot ang langis ng konte,
    then i start to roll, and shift at low rpms hanggang
    umabot na sa operating temp.
    pero pag hindi nagamit yung car ng more than 3 days,
    paabutin ko din ng 1.5 minutes, para malangisan ulit mga
    singit2x ng engine internals.
Warm up the engine??
