Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 55
    Mar 2007
    My grandfather died 5 years ago and he left a kia picanto in his garage. I tried to start it kanina however it only cranks. I already filled it with fresh gasoline 4 liters but it still would not start. Engine oil is fine. Fuel line is fine no leaks. This was in good running condition before he left the mortal world.
    Any troubleshooting tips?
    Jan 2011
    check fuel line, electrical lines like spark plugs, ht wires, distributor.
    Sent from my SM-G610Y using Tapatalk
    voltage is ok? spark plugs could be rusty?
    Mar 2007
    Have not checked it pa. Unahin ko siguro fuel line baka barado. Saan ba makabili ng spray yung nilalagay sa intake manifold if it starts? Ano tawag nun?
    Mar 2007
    Quote Originally Posted by shelu View Post
    It cranks good. How to check spark plugs ba? Ito mahirap mag diy pag walang tamang tools hehe
    Jan 2011
    mas maigi siguro, tawag ka ng mekaniko. para ma check na lahat. kahit andar pa yan, di mo pwede i drive yan. stuck up na ang brakes nyan, delikado.
    Jan 2013
    Even if it cranks, ok pa ba battery? 5 years of no charging yan.
    Sent from my ONEPLUS A3000 using Tapatalk
    Did you drain the old fuel? They do have an expiration date kahit nasa tangke lang.
    Drain the tank, put fresh fuel, replace the fuel filter and try it again.
    Jun 2015
    Hindi ba delikado paandarin dahil wala nang langis sa engine parts? I assume all the engine oil has dripped down and the cylinders are all dry.
    lahat nman ganyan. oil pump is driven by chain/belt. a few days lng oil goes down but of course a liter or so remains in some galleries.
    as he mentioned, nag crank na.. oil already circulated..
Vehicle not started for 5 years... What to do?
