Results 1 to 10 of 55
July 16th, 2018 09:28 PM #1
My grandfather died 5 years ago and he left a kia picanto in his garage. I tried to start it kanina however it only cranks. I already filled it with fresh gasoline 4 liters but it still would not start. Engine oil is fine. Fuel line is fine no leaks. This was in good running condition before he left the mortal world.
Any troubleshooting tips?
July 16th, 2018 09:31 PM #2
check fuel line, electrical lines like spark plugs, ht wires, distributor.
Sent from my SM-G610Y using Tapatalk
July 16th, 2018 09:33 PM #3
voltage is ok? spark plugs could be rusty?
July 16th, 2018 09:35 PM #4
July 16th, 2018 09:36 PM #5
July 16th, 2018 09:40 PM #6
mas maigi siguro, tawag ka ng mekaniko. para ma check na lahat. kahit andar pa yan, di mo pwede i drive yan. stuck up na ang brakes nyan, delikado.
- Jan 2013
- 1,851
July 16th, 2018 11:03 PM #7Even if it cranks, ok pa ba battery? 5 years of no charging yan.
Sent from my ONEPLUS A3000 using Tapatalk
July 16th, 2018 11:55 PM #8
Did you drain the old fuel? They do have an expiration date kahit nasa tangke lang.
Drain the tank, put fresh fuel, replace the fuel filter and try it again.
- Jun 2015
- 2,751
July 17th, 2018 12:25 AM #9Hindi ba delikado paandarin dahil wala nang langis sa engine parts? I assume all the engine oil has dripped down and the cylinders are all dry.
July 17th, 2018 12:34 AM #10
Anong Chinese brand na ba ang available sa market? Yung Leoch brand may nakita na ko post sa FB....
