Valve clearance adjustment for your car is 0.9 hours at the dealership flat rate and 1.3 hours commercial. This gives you ample time before the engine cools off. Even if you multiply it by two the engine would still be hot enough. E series engine flaw lies in the insufficient lube to the fulcrum of the rocker arms an eventually lead to wear. Check the ball and socket fulcrum end for wear
