Results 1 to 10 of 46
April 29th, 2005 10:26 AM #1
Mga bro,
i saw this device being sold here in Ayala Center, Cebu. gas-saving device na ikinakabit sa loob ng hose na daluyan ng air papuntang intake manifold. it makes the air swirl as it enters the combustion chamber, thus promotes better air/fuel mixture and efficient combustion. they have a 10-day moneyback guarantee, it costs 2500 bucks free installation
what can you say about this mga tsikoteers? im sure you heard about it na. although i want to satisfy my curiousity, i just also want to know if 10 days is already enough to know kung ano side effect ng device (if any). for those who have tried it and were not satisfied, binabalik ba nila kaagad ang pera mo right there and then without hassles?
Check out their website: http://www.uniqpoint.com
i think pinalitan na nila ang name into ECE (Engine Combustion Enhancer)
April 29th, 2005 10:32 AM #2
mmm... 10 days isn't enough. But honestly I wouldn't buy any of those "fuel saving" devices unless tested... AFAIK puro marketing lang yan.
- Oct 2004
- 132
April 29th, 2005 11:17 AM #3Same concept with the turbonator (http://www.turbonator.com/).
Do a search for turbonator in this forum and you'll have some ideas pre.
Good luck.
April 29th, 2005 02:34 PM #5
ghosthunter,
medyo bitin lang ako sa comment mo, if possible, could you explain why? nasubukan mo na ba? or meron ka bang kakilala na nakasubok na and had negative feedbacks about it? i really need your inputs here. bat mo nasabing waste of money kung money-back guarantee naman?
April 29th, 2005 02:36 PM #6
Ako one liner din ang sagot... http://www.fuelsaving.info/turbulence.htm
Eto na lang. If that were true, everybody would be putting it in, sa manufacturer pa lang.
April 29th, 2005 02:51 PM #7
revelcop: Check the khaos thread under car talk. You'll find it interesting...
April 29th, 2005 03:03 PM #8
i agree with wildthing. if that technology has been found to improve combustion, car manufacters pa lang maglalagay na ng ganyan.
April 29th, 2005 06:48 PM #9Originally Posted by ravelcop
ako pa yung naging defensive. At any rate, the "ECE" device will cause "swirls" in the air but those same swirls will not reach the combustion chamber given the twists and turns of the engine's intake manifold all the way to the cylinders. All it does is create a constriction in your engine's intake, the loss of flow would be more pronounced at the top end of your engine's rpm range.
Big waste of money because you will still have to "test" the effectivity of the device in ten days. Then if you feel it is not effective, you will still have to drive your car back to the dealer. Theoretically he will immediately give back your money. But thats hardly the case, he would probably need to "test" your car as well. he might also give other excuses as well. Given that time is money, the more time you waste with "testing", you are also wasting money.
We can already know that devices like the "ECE" does not work as claimed so why bother trying the "Nth" version that came out on the market?
April 29th, 2005 06:57 PM #10Originally Posted by ghosthunter
and even if it is placed right before the combustion chamber, the swirl generated will be negated by the speed of the air flow.
Eto yung best chance mo for troubleshooting kung saan ba talaga galing leak. Also, precaution...
Coolant...
