Results 21 to 27 of 27
- Sep 2006
- 1,335
March 1st, 2010 11:59 PM #21sir, wala po boost gauge ang shop..
By the way, may play ba ang shaft ba ng Turbo or is it fixed/steady talaga?
Meron endplay and radial play ang turbo.
- May 2006
- 424
March 2nd, 2010 06:40 AM #22Thanks, today I will ask the mechanic to clean and check the inlet and exhaust manifold.... whew... parang ako ang instructor ng mechanic..
Thanks guys sa mga tips, I will keep this post updated kung ok na ang paj ko.
Thanks thanks
- Aug 2009
- 7
March 2nd, 2010 08:53 AM #23THE MOST IMPORTANT PART, check mo ang mga gasket nung manifolds and hoses leading pressure in and out of the engine for possible leak. Change the gasket para sigurado ka na talaga, anyway mura lang naman yan. i know someone who had the same problem like yours, parehong pareho talaga with all those symptoms, procedures and solutions he had resorted to, gumasto rin ng malaki, only to find out its the gasket of manifolds. UNBELIEVABLE?!!! YET ITS TRUE. Good Luck.
- Jun 2008
- 1,741
March 3rd, 2010 02:26 AM #24Di kaya clogged up yang inter-cooler? Yung dumi sa loob ng turbo compressor ay naitulak sa intercooler? Mag resulta ito ng "turbo surging", malakas na tunog ng hangin. Suggestion ko ay ibaba ang inter-cooler at linisan ang airside (air fins).
Leaky connection between turbo-intercooler-engine ay isang source ng hissing sound.
- May 2006
- 424
March 3rd, 2010 05:42 AM #25
- May 2006
- 424
March 4th, 2010 08:30 AM #26So far, we cleaned the manifold (inlet and exhaust), we used an egr, intercooler and a turbo from a friend, whom I thankful I was able to borrow the parts I needed for testing…
We found an unexplainable factor affecting the turbo…
The egr valve, if blocked, will cause the inlet hose to be very hard or full of pressure… results in the loud wheezing of turbo (maybe due to over pressure.. tama po ba?)
If the egr valve will be left open, knocking sound and black smoke appears upon rev, plus loss of power results…
Can anyone figure this out for me? Thanks
- Jun 2008
- 1,741
March 4th, 2010 10:02 AM #27Last edited by weisshorn; March 4th, 2010 at 10:09 AM. Reason: additional text
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
