Results 11 to 20 of 27
- Sep 2006
- 1,335
February 23rd, 2010 09:04 AM #11
- May 2006
- 424
February 23rd, 2010 07:47 PM #12diagnosis is done... may sira ang turbo propeller... can anyone help me find a good turbo replacement or surplus? or is there other way to fix the propeller?
- Sep 2006
- 1,335
February 23rd, 2010 09:43 PM #13
- May 2006
- 424
February 24th, 2010 05:15 AM #14The mechanic told me he never touched the turbo. this is cause by wear and tear... either way, I need to get it fix or replace....
Some recommended to buy a surplus or replacement, other said just replace with the turbo kit (mas ok ba ito?).... Maayos po ba ito ng machince shop?
- May 2006
- 424
February 28th, 2010 06:01 AM #15
- Aug 2009
- 7
February 28th, 2010 09:17 PM #16hi peps,
i am also a newbie in this forum. FOR DUDEE please try to clean your inlet and exhaust manifold and try to check if there are any leaks on its gasket,try mu na rin icheck ang mga hoses. Please post the result if these procedures solve your problem or not., or if ok na ang ride mo what have you done to fix the problem?
Thanks
- Sep 2006
- 1,335
February 28th, 2010 09:21 PM #17
- May 2006
- 424
March 1st, 2010 06:15 AM #18The mechanic told me that the turbo is bad, and yes, I did install a used turbo.
I found a leak in the tube (i don't know what it's called), it is connected with the EGR (pero condemned na). Today, I will totally remove the egr and covered it my a plate to see if it makes any difference.
If it will not work, I will have look where I can borrow an intercooler, just to make sure before I would buy another one.
We had cleaned and washed the intercooler, we tested it by pushing air (using compressor), so far, dumadaan po. Tama po ba ang testing namin?
Hope this will fix it.
- Sep 2006
- 1,335
March 1st, 2010 07:38 PM #19The mechanic told me that the turbo is bad, and yes, I did install a used turbo. Used turbo is fine as long as it is in good working order. Have you checked this 2nd turbo?
I found a leak in the tube (i don't know what it's called), it is connected with the EGR (pero condemned na). Today, I will totally remove the egr and covered it my a plate to see if it makes any difference. Ok.
If it will not work, I will have look where I can borrow an intercooler, just to make sure before I would buy another one. Ok.
We had cleaned and washed the intercooler, we tested it by pushing air (using compressor), so far, dumadaan po. Tama po ba ang testing namin? Mali. Air compressor supplies high pressure/low air volume. Air passing through the intercooler is low pressure/high volume. The correct way is to put boost gauges before and after the intercooler to measure pressure differential with the engine loaded. Alternative way is just to measure boost pressure between the intercooler's discharge and the engine's intake pipe at full load.
Hope this will fix it. Sana....
- May 2006
- 424
March 1st, 2010 08:07 PM #20sir, wala po boost gauge ang shop..
By the way, may play ba ang shaft ba ng Turbo or is it fixed/steady talaga?
Daming issue ng SU7:grin:
Xiaomi E-Car
