Results 41 to 50 of 58
October 27th, 2010 06:35 PM #41
October 27th, 2010 06:57 PM #42
The avanza has high center of gravity, magaan, relatively makitid. hindi talaga designed for speed. I would not imagine the avanza stable at more than 180 or 200 kph.
October 27th, 2010 07:02 PM #43
- Dec 2005
- 52
October 28th, 2010 12:09 AM #44Hi GH!
Thanks for the info provided. I was able to talk to SpeedLab personnel, sadly it would cost me 200K (including gauges, etc) to put turbo kit to an Avanza unit.
Initially, I was thinking of getting turbo kit from US as I was able to find one selling in ebay http://cgi.ebay.com/ebaymotors/Toyot...-/260481895100
(no, im not connected to them, and seems the same turbo kit is used for different vehicles...hmmmm).
So from the cost, it seems it is practical to go for a 1.5L Avanza.
You mentioned that typically, there would be a 1KM/L drop to fuel consumption when turbo kit is installed. Does this mean that turbo-enabled 1.3L Avanza might consume more fuel than stock 1.5L Avanza? I am under the impression that a 1.3L turbo-enabled Avanza would consume less fuel than 1.5L
Another option for me is to buy a 2nd hand 1.3L Avanza...and if there are other reputable shop who can do installation and tuning...please let me know.
October 28th, 2010 09:32 AM #45
The 1.3J-turbo can be driven very conservatively to consume less fuel than the Avanza 1.5L but that totally depends on two things, tuning and the driver. The tuning shop can handle the tuning. But if the driver feels the need for speed often, the fuel consumption will definitely increase.
Remember: It takes more fuel to make more power.
So given that your 1.3J-turbo makes the same power as a typical 1.8L engine, it has the potential to consume fuel just as much if you drive it like it was a 1.8L engine under your hood.
It is just like having a 2.0L car that can do 15km/L. It can be done, but you will have to drive like my grandmother to achieve it. It won't be fun and you will not be using the engine's true potential.
The estimated 1km/L increase in fuel consumption is an estimate based on if there was almost NO CHANGE in typical driving habits.
Power mods typically throw out fuel economy out of the window.
October 28th, 2010 10:01 AM #46
At what RPM sisipa ang turbo?
at 3,000 rpm, the avanza J runs 80 kph at 5'th gear.
sa MR2 sabi ng nakausap ko na may ari, sumisipa daw ang turbo at 3,000 rpm. para matipid daw, hindi nya pinaabot dito. so kung sa avanza, less than 80 kph ang takbo para matipid kung naka turbo na sumisipa at 3,000 rpm.
October 28th, 2010 10:06 AM #47
pangit ang traction ng stock tires. low rolling resistance. for me, stable naman at 140kph using 205/50 tires. driver lang ang sakay.
rear stabilizer pa lang ang suspension upgrade ko. not useful sa straight roads.
if there is a strong crosswind, not advisable to go more than 120 kph (or even at 100kph).
October 28th, 2010 10:18 AM #48
October 28th, 2010 12:04 PM #49
kung mag turbo, i think it will be good to upgrade the rear differential to Hi speed tapos with LSD pa. :D
pati pala clutch dapat palitan.
October 28th, 2010 12:16 PM #50
But that would definitely exceed the budget.
And with a max hp of only 130hp, I don't think an LSD and high speed differential would be needed.
In this case, an upgraded clutch would not be needed unless the owner would want to drag race his Avanza. The stock clutch would do fine until it's time to be replaced.
Yeah, if you know, you know.
