Results 31 to 40 of 58
March 29th, 2008 10:34 AM #31
- Dec 2005
- 52
October 26th, 2010 01:38 AM #32
October 26th, 2010 09:42 AM #33
You can get a kit from a shop like Speedlab for around 150k pesos. You can build your own for around 100k or less using surplus/used parts and by hunting around.
October 26th, 2010 10:03 AM #34
- Dec 2005
- 52
October 27th, 2010 12:12 AM #35Hi GH,
If let's say the purpose is just to increase torque / hp but not necessary for speed racing, would that mean also there's a need to upgrade brake system and suspension?
Im just playing the idea of getting 1.3J, then if possible put bolt on turbo kit (from K3-VE to K3VET) for me to have more torque/hp instead of getting 1.5G avanza.
Im planning to upgrade my ride... family is getting bigger (2 kids plus nanny) during weekend. Plus once a month long drive.
My 1.3 97Exi seems to be OK (in terms of torque/hp), so I was thinking if there's a possibility to increase torque / hp of 1.3 avanza instead of putting 190+ on 1.5G (which would increase If I take interest expense if I take it via leasing/financing).
Sorry I am not really good in this area...(I just got the mentioned here on the internet). Your opinion is highly appreciated.
October 27th, 2010 01:06 AM #36
The 1.3L engine does 92hp stock.
Adding a turbo at 6 to 8 psi would give you around 120 to 130hp and also proportionally more torque as well.
The stock 1.5L only does 109 hp (as a comparison).
The compression ratio of the engine is 10 to 1. That means you cannot increase the boost too much without blowing up the engine. It also means the turbo will significantly increase the internal stress of the engine and shortening the life of the internal wear/tear parts.
As for the need to upgrade brakes and suspension to handle the added power, I do strongly suggest it. Minimal would be better brake pads.
In my test drive of the Avanza 1.5L, it really felt unstable at maneuvers in higher speeds. I am not sure what upgrades would be most effective in making it more stable for the least money. Maybe a rear stabilizer bar or stiffer suspension springs would be enough but that is just a guess. You could probably ask the Avanza guys for their opinion on this part.
But if you think you can restrain yourself from speeding too much, you can probably go with the brake pad upgrade.
The danger, you might be spending more money in modifying an Avanza 1.3J
to have more power than the savings of P190+T from avoiding to buy the Avanza 1.5 or in the very least, your "savings" will not be as big to be worth it. Your potential savings of P40,000 might end up to be smaller.
Plus side, if you do get the 1.3 turbo set up properly tuned, you can have the best of both worlds. An engine that is (relatively) powerful for quick accelerations yet economical on the fuel.
If you are willing to leave the brand new Avanza at Speedlab for a few weeks for a custom turbo kit to be done, I suggest you talk it over with Ferman of Speedlab, QC with your plan and budget. Best to get his opinion on the feasibility of turbocharging the 1.3l engine.
BTW, a turbocharged engine will need extra care for longer life. Never shut-off a hot engine, let it idle for a few minutes to let the turbo cool down so you don't burn the oil in the turbo's bearings (or an automatic turbo-timer would help you here). Full synthetic oil might be recommended. "Cold" sparkplugs as well (they don't cost much more than regular plugs). Either a boost guage, oil temp guage or both might be recommended to keep an eye on the engine.Last edited by ghosthunter; October 27th, 2010 at 01:27 AM.
- Dec 2005
- 52
- Dec 2008
- 421
October 27th, 2010 02:59 PM #38If it's just a 1.3 why not swap in a larger engine. I would only suggest turbos only if the engine is getting too large and is starting to impose a high weight penalty to the chasis and affects handling already. Always remember, turbo or larger engine, you need to upgrade your other parts esp the brakes to control the increased power
October 27th, 2010 06:25 PM #39
October 27th, 2010 06:29 PM #40
Does having a turbo mean a significant increase in FC? Im toying with the idea also. Pero natatakot ako sa associated cost (installation, tuning, reliability, etc).
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
